Data Assist Recordset MySQL Error when try to expand
Thread begun 1/15/2012 6:15 pm by toni272059 | Last modified 1/16/2012 6:57 pm by Ray Borduin | 12836 views | 7 replies |
toni272059
I have been working thru the DataAssist Getting Started Guide. Everything was going smoothly until I reached Customizing your Pages, Details.php.
When I try to Expand the Recordset in the Bindings Panel I receive the following error
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'group, `item-id`, item, `item-photo`, item-desc, `item-size`, item-price FROM `b' at line 1
I have gone thru the DataAssist Wizard twice trying different settings. The MySQL table items are all set to VARCHAR or TEXT or MEDIUMBLOB (for photos) . Database was created on my local computer using MAMP
If I try to open a file on my local computer in the browser the following error loads
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-products-table ORDER BY item LIMIT 0, 1000' at line 1
Follows content of exported .sql table. What am I missing...?
-- phpMyAdmin SQL Dump
-- version 2.11.7.1
-- www.phpmyadmin.net
-- Host: localhost
-- Generation Time: Jan 15, 2012 at 09:12 PM
-- Server version: 5.0.41
-- PHP Version: 5.2.6
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
-- Database: `boomerang-products`
-- Table structure for table `boomerang-products-table`
CREATE TABLE `boomerang-products-table` (
`maincategory` varchar(55) NOT NULL,
`subcategory` varchar(55) NOT NULL,
`group` varchar(55) NOT NULL,
`item-id` varchar(15) NOT NULL,
`item` varchar(55) NOT NULL,
`item-photo` mediumblob NOT NULL,
`item-desc` text NOT NULL,
`item-size` varchar(55) default NULL,
`item-price` varchar(11) NOT NULL,
PRIMARY KEY (`item-id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
-- Dumping data for table `boomerang-products-table`
It may not like the dashes in your table name. A dash will look like you are trying to subtract in your sql statement. Try using underscores instead of dashes in your table names.
toni272059
I have tried changing the database table field names to use underscores, I have deleted files and started again with Data Assist. Everytime I have the same problem with the Recordset error. The latest error message is
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'group, product_number, item_name, item_photo, item_desc, item_size, item_price F' at line 1
I have tried changing field names, field types.
Follows the latest sql file content and also the php at head of Details page
-- version 2.11.7.1
-- Host: localhost
-- Generation Time: Jan 16, 2012 at 03:25 PM
`item_id` int(10) unsigned NOT NULL auto_increment,
`product_number` varchar(25) NOT NULL,
`item_name` varchar(55) NOT NULL,
`item_photo` mediumblob NOT NULL,
`item_desc` text NOT NULL,
`item_size` varchar(55) default NULL,
`item_price` decimal(5,2) NOT NULL,
PRIMARY KEY (`item_id`),
UNIQUE KEY `product_number` (`product_number`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=2 ;
<?php require_once('../Connections/Boomerang.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
?><?php
$Paramitem_id_WADAboomerangproductstable = "-1";
if (isset($_GET['item_id'])) {
$Paramitem_id_WADAboomerangproductstable = (get_magic_quotes_gpc()) ? $_GET['item_id'] : addslashes($_GET['item_id']);
$ParamSessionitem_id_WADAboomerangproductstable = "-1";
if (isset($_SESSION['WADA_Insert_boomerangproductstable'])) {
$ParamSessionitem_id_WADAboomerangproductstable = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_boomerangproductstable'] : addslashes($_SESSION['WADA_Insert_boomerangproductstable']);
$Paramitem_id2_WADAboomerangproductstable = "-1";
$Paramitem_id2_WADAboomerangproductstable = (get_magic_quotes_gpc()) ? $_GET['item_id'] : addslashes($_GET['item_id']);
mysql_select_db($database_Boomerang, $Boomerang);
$query_WADAboomerangproductstable = sprintf("SELECT item_id, subcategory, group, product_number, item_name, item_photo, item_desc, item_size, item_price FROM `boomerang-products-table` WHERE item_id = %s OR ( -1= %s AND item_id= %s)", GetSQLValueString($Paramitem_id_WADAboomerangproductstable, "int"),GetSQLValueString($Paramitem_id2_WADAboomerangproductstable, "int"),GetSQLValueString($ParamSessionitem_id_WADAboomerangproductstable, "int"));
$WADAboomerangproductstable = mysql_query($query_WADAboomerangproductstable, $Boomerang) or die(mysql_error());
$row_WADAboomerangproductstable = mysql_fetch_assoc($WADAboomerangproductstable);
$totalRows_WADAboomerangproductstable = mysql_num_rows($WADAboomerangproductstable);?>
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $Boomerang;
$WA_table = "boomerang-products-table";
$WA_redirectURL = "boomerang_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "item_id";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_Boomerang;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
"group" is a reserved word in mysql. You need to avoid using any of these reserved words as column names:
reserved-words.html
toni272059
OK, I changed the field names (plus some other changes noted below) and tried to restart DataAssist Wizard. Now it does not see the Key Column/Primary Key, gives me a MM_ERROR: An unidentified error has occured.
I checked some other forum posts for MM_ERROR but do not see what could be wrong with my database table.
I have tried renaming the database, the table. Emptying cache. Deleting the &#65279;WinFileCache.dat file. Uninstalling and reinstalling Data Assist. Creating a new dynamic site. Creating new .dwt and .php files.
Using phpMyAdmin I inserted two entries into the table because I wanted to create a Menu option in the Insert page for the main category to be either Standard Products or Custom Products
I also changed some of the fields so they are not Required because the Custom Products do not have content for all Fields
ZIP attached with the latest .sql table
The unidentified error has occurred message usually means that DW can't communicate with your database server. This is usually because the url setting in your site definition is wrong.
Are you able to edit and test your Connection without errors? Start by verifying that you can test your database connection by opening the define connection dialog and clicking the test button. If you get the same error, that means your site definition testing server doesn't have the correct url and/or default directory specified.
toni272059
Yes, I can connect to the database. See attached screen grab showing Dreamweaver, Dynamic MySQL Connection and Data Assist windows.
The Dreamweaver Database window shows the Table and all the fields. One of which is identified as a primary key.
I've opened a support incident so that we can have someone call and debug this with you directly. Please update the incident with a phone number and good time to reach you and we'll help figure out exactly what is going on.
