Form Builder Contact From CSS Layout Issue - Big Gap or Space
Thread began 1/14/2012 3:07 pm by greg_herr420504 | Last modified 1/16/2012 5:34 pm by Ray Borduin | 1386 views | 3 replies |
greg_herr420504
Hello,
I'm assuming this is a very easy CSS fix, but as I'm still learning my way around using CSS for layout I'm banging my head against the wall on this one... I created a simple contact form using form builder and dropped it into a template I'm using on my website. Everything is working, but the div with the form seems to effected by other divs and the content in the form gets pushed down. I've checked and unchecked - changed and unchanged just about anything I could in the CSS setting but no luck. When I change the positioning 'relative' it looks correct in dreamweaver, but I still get the space in browsers when pushed live. Any help would be appreciated!
Thanks,
Greg
Live Link -> contact.php
pages.zip
file: fd_compact_default.css
line: 138
remove: clear:both;
greg_herr420504
Thanks!
Worked perfectly.... Now I just need to figure out why on my own. : ) You guys rock!
Try installing Firebug for firefox. It is an excellent tool for debugging css and html. It was what I used to figure out why it was doing what it was doing.
