Order Number showing code instead of Order Number to customer
Thread begun 1/13/2012 8:51 am by brandoli400690 | Last modified 1/19/2012 1:58 pm by Jason Byrnes | 2929 views | 3 replies |
brandoli400690
Hi there
When returned to our site from Paypal the Order Number on the page is showing code instead of Order Number to customer.
Should be Order #63.
I've attached a screen shot.
Thanks very much
Please send me a copy of that page referenced in the url so I can take a look. I'm looking at my version and it appears to have the correct code, but you may have an earlier version so I'll look and suggest what you might need to updated.
brandoli400690
Order # showing as code in checkout success
Your file types don't support .php so here is the code from this page:
if (!empty($_SERVER['HTTPS'])) {
header("location: http://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI']);
die();
require_once('webassist/themes/theme_open.php');
$WAIncludeContent = new WA_Include(__FILE__);
$WAeCart = new WA_Include('webassist/plugins/shopping_cart/cart_readonly.php');
require($WAeCart->BaseName);
$WAeCart->Initialize(true);
<html><!-- InstanceBegin template="/Templates/themed_content.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->
<title>Checkout Success - <?php echo($WAGLOBAL_Site_Name); ?></title>
<!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="head" -->
echo($WAeCart->Head);
</head>
<body>
<!-- InstanceBeginEditable name="banner" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="searchform" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="main" -->
<h1>Order Receipt
Order # <?php echo(date('h')); ?>-<?php echo(date('d')); ?>-<?php echo (isset($_SESSION['OrderID'])?$_SESSION['OrderID']:session_id()); ?>-<?php echo(date('m')); ?>-<?php echo(date('y')); ?>
</h1>
<div class="contentBox ps_pod1 borderColor">
// if in test mode, skip all checkout code
if ($WAGLOBAL_Test_Mode == true) {
<h3 class="errorText">Your site is in Test Mode. You will have to uncheck the Test Mode option from the General tab on the Admin Settings page before payments will be processed.</h3>
<p><strong>Thanks for your order!</strong><br>
Please save or print this receipt for your records. Do not refresh this page or attempt to open it in another window. A copy of this reciept has been emailed to you.
</p>
// Determine if at least one product in the cart has a digital download. Need to remove spaces and commas as TotalColumn will return a comma space separated list of entries.
$coSuccess_cartDigitalGoods = str_replace(",", "", $WA_Store_Cart->TotalColumn("DigitalGood"));
$coSuccess_cartDigitalGoods = str_replace(" ", "", $coSuccess_cartDigitalGoods);
if($coSuccess_cartDigitalGoods != "" && $coSuccess_cartDigitalGoods != "0"){
<form action="view_downloads.php" method="POST" name="form" id="form">
<input name="downloads" id="downloads" value="View Downloads" class="ps_buttons" type="submit">
</form>
</div>
<br />
echo($WAeCart->Body);
<br /><br />
<!-- InstanceBeginEditable name="sidebar" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="sidebar2" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="end" -->
</body>
<!-- InstanceEnd --></html>
<?php require_once('webassist/themes/theme_close.php'); ?>
if ("" == ""){
// WA_ClearSession
$clearAll = FALSE;
$clearThese = explode(",","OrderID,WA_Store_Cart_Items,_3DS_Lookup_ViewData,_3dsTransactionID,_3DS_POST_Data,_3DS_AdditionalParams");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
it's hard to tell from the screen shot what is on the page, can you send another screen shot in a zip archive so i can get a better idea of what is going wrong?
also, what payment gateway are you using?
