web assist code not liked by CS5.5
Thread begun 1/11/2012 3:01 pm by JBWebWorks | Last modified 1/12/2012 3:52 pm by JBWebWorks | 2454 views | 2 replies |
JBWebWorks
Upgraded to DW CS5.5 and using the validate page to W3C and they didn't like some code for Web Assist Validation toolkit.
example:
<input name="name1" type="text" id="name1" value="<?php echo(ValidatedField("contactus","name1")) ?>" />
an attribute value literal can occur in an attribute specification list only after a VI delimiter [XHTML 1.0 Transitional]
end tag for "input" omitted, but OMITTAG NO was specified [XHTML 1.0 Transitional]
Question-Should i worry about this?
the Dreamweaver File -> Validate -> Validate Currant Document (W3C) command copies the entire source code of the page and sends it to be validated by the W3C, this includes the raw php code on the page. That will never validate correctly, because php cannot be validated as HTML code.
To be able to validate the page correctly using the dreamweaver command, you need to set a remote server in your site definition, and use the File -> Validate -> Validate Live Document (W3C). This will be basically the same as going to the W3C validation site:
validator.w3.org/
and entering the address for the page on your site to validate.
JBWebWorks
thanks Jason,
works fine and easier too.
