I'm having a problem with checkbox groups
Thread begun 1/11/2012 12:21 pm by cgdm93096 | Last modified 9/06/2012 8:34 am by Jason Byrnes | 6612 views | 12 replies |
cgdm93096
I have two checkbox groups on a form so that I’m able to have multiple selections. The contents of the submitted email from the checkbox groups both come back saying “array” instead of the selected list values. The rest of the content of the form is coming through correctly.
I’m using CSS Form Builder 2.01_SR2 with Dreamweaver CS5 on Windows 7.
add the following code to line 1 of the page:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
cgdm93096
That corrected the problem and thanks for the quick reply!!
info72555
I feel silly for not being able to get this to work :o(
I inserted this code at the top of the template. The values are now being shown correctly when I receive the message (it showed "Array" previously).
The problem is that after submitting the form I now get a whole bunch of error messages like:
- Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\inetpub\vhosts
- Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent
- Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\inetpub\vhosts\
I have read other posts about fixing the issue of having check box groups create an "Array" error in the output email but I cannot figure out what code to insert where because it does not work for me...
Please help...
the code to convert the array should not be added to the email template, it should be added to the form page.
the error you are getting will happen as a result of output between php tags. See the following thread for more details:
showthread.php?t=19285
info72555
Using the code in the Form...
I tried that previously - no luck. Once I submit the form I get very similar error messages.
The code:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
// This code needs to be added for checkbox groups
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
// End code
if (isset($_POST["PlantCare_submit"])) { ......
--- Errors:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php on line 85
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php on line 85
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\webassist\email\mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\webassist\email\mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php on line 115
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php:12) in D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.php on line 115
the error is saying that there is output at line 12:
output started at D:\inetpub\vhosts\plantcare.ca\httpdocs\Contact.ph p:12
that is causing the error.
normally it is caused by a blank space or line between php tags.
i would need a copy of the Contact.php page to troubleshoot any further.
info72555
Thank you in advance :o)
The entire file was 22 kb so I hope the condensed version helps...
well, lines 1 -13 are:
    foreach(
        if(
// End code
line 13 has a blank space at the end that is causing the error:
delete the space after the closing php tag to correct the error
info72555
Thank you Jason!!
Now here is my question: this code (with the blank spaces) is generated by Form Builder so I am now wondering whether there is a fix/patch for your extension to prevent blank spaces from being inserted in the first place? What confused me is that the form works perfectly fine if I don't use checkbox groups.
Can you make a recommendations to help avoid this glitch? I vaguely recall I was asked to replace a "WAFB_ListValues.htm" file but that was for DW CS4 so I was not sure if it applies to CS5 as well.
Any suggestions?
Your support is outstanding - I have never come across any company responding as quickly as you do so THANK YOU!!!!! :o)
