Search Logic DA 2.0.8
Thread began 1/11/2012 9:35 am by Steve | Last modified 1/11/2012 3:23 pm by Steve | 1105 views | 2 replies |
Steve
In the screen shot attached I am showing the results from using an OR search condition.
The goal was to search # of Bedrooms and Bathrooms OR search using Sqr Ft based on a min and max range selected from two select lists.
Is there something more than the Solutions PDF that explains the logic and methods needed to achieve this goal?
Do I need separate the groups in their own forms so only those values are submitted via a separate button (isolating the values of each OR condition/group)?
DataAssist Search soes not have the ability for grouping search items.
but, if you don't enter a value in one of the form element, that column wont be included in the filter that is generated.
In other words, if you enter a number of bed rooms, but don't enter anything in the square feet, it wont include square feet in the filter that is created.
just make sure when use select lists, that you include a blank value option:
<option value="">make A selection</option>
Steve
Thanks Jason, the backend not using blank or null values will work just fine to achieve my goals.
