Description of each image not showing
Thread begun 1/09/2012 8:05 pm by dennis372614 | Last modified 1/10/2012 8:37 am by dennis372614 | 1571 views | 2 replies |
dennis372614
I added images and in the description box I added what each item picture represented.
The only one that shows is the last one image I added and added description>
here is the link to gallery. hovering over image displays the description on the chapel window, Stained Glass. The rest do not?
index.php?gallery=1&theme=dark
Dennis
the problem is caused by using double quotes in the description:
"CEDAR BOX"
try using the quote HTML entity instead:
"CEDAR BOX"
dennis372614
Problem Solved!
Thanks very much Jason!
That did the trick!
Great technical support!
Dennis
