Warning: file_exists() [function.file-exists]:
Thread began 1/09/2012 4:17 pm by contactus306424 | Last modified 8/09/2012 8:10 am by Jason Byrnes | 1865 views | 3 replies |
contactus306424
I just started to get these warnings, can anyone assist please.
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.css) is not within the allowed path(s): (/home/thegreen:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/index.php on line 100
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.php) is not within the allowed path(s): (/home/thegreen:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/index.php on line 220
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.js) is not within the allowed path(s): (/home/thegreen:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/thegreen/public_html/cms/HTMLEditor/editor/plugins/kfm/index.php on line 221
lcharles360099
same problem
i am having the same problem as above. website is hosted with media temple.
the issue is caused by having the open_basedir restriction enabled in the php server.
you will need to contact the host to have them disable the open_basedir restriction, the Files manager of Power CMS will not work correctly with the open_basedir restriction enabled.
