DA Insert Page and UE4
Thread begun 1/09/2012 12:14 pm by Jon Cunningham | Last modified 1/10/2012 6:50 am by Jason Byrnes | 1811 views | 2 replies |
Jon CunninghamBeta Tester
Hi Guys,
Not sure if anyone can point me in the right direction.
I have an insert form created with DA. I have added UE4 to the insert form and upon submit an email is sent. All good so far.
The body of the email does contain the insert data, however the field name to the left of each content shows as the database column name.
I have tried renaming the input "name" but if I do this the contents of the form is emailed to me but the data base column data does not get written to the DB.
Is there a work around so that I can rename the field name in the email body to something better that the database column name.
Hope that this makes sense
Kind regards
Jonathon
Solved
Hi Guys,
Found the solution by changing the following
<?php echo(str_replace("_"," ",$pkey)); ?>
eg
<?php echo(str_replace("Trainee"," ",$pkey)); ?>
This Removes the word Trainee from the Array
Jonathon
you could use:
<?php echo(str_replace(array("Trainee", "_")," ",$pkey)); ?>
this would remove both the underscore and the string "Trainee"
