Custom validation messege
Thread begun 1/07/2012 2:20 am by steelace396915 | Last modified 1/10/2012 9:22 am by steelace396915 | 2946 views | 5 replies |
steelace396915
Hi
I have a column in my database for various accesslevels to my site. I have set this up with 4 levels (admin = 4, student = 3, registered = 2 and visitor = 1). When a user register he is assigned accesslevel 2 in database
On my loginpage built in SA I have set up a rule allowing accesslevel 3-4 to login successfully and also restricted accesslevel 2 since I don't want registered users to access my site until they are approved. When a user who has just signed up through the registration page is transfered back to the login page and tries to login with his registered email and password he won't be able to login since the rule is set to restrict accesslevel 2 users. I solved this by redirecting unsuccessful logins to another page where Ive just set up 2 server behaviours, clear all sessions and server redirect back to the login page. All this works good.
My question is how I can show a messege to a registered user when he's transfered back to the login page after a unsuccessful login attempt, displaying that he can't login to site until his registration has been approved?
Thanks in advance!
/Martin J.
in the server redirect behavior, set the redirect to the login page to pass a querystring variable, such as:
login.php?notAuthenticated=true
then add an if statement on the login page:
<?php if(isset($_GET['notAuthenticated'] && $_GET['notAuthenticated'] == "true" ) { ?>
you will not be able to login to this site until your registration has been approved.
<?php ?>
steelace396915
Thanks Jason! I tried this but I get error messege in code when inserting the block on the login page? Where do I put this code? Ive enclosed screen image from dreamweaver!
Thanks in advance!
/Martin J.
sorry, this line:
should be:
<?php if(isset($_GET['notAuthenticated']) && $_GET['notAuthenticated'] == "true" ) { ?>
steelace396915
Thanks Jason! I will try it again!
/Martin J.
steelace396915
That worked great Jason! Many thanks!
/Martin J.
