Alternative text for images
Thread begun 1/06/2012 7:56 am by tjones368861 | Last modified 1/10/2012 12:07 pm by Jason Byrnes | 3452 views | 8 replies |
tjones368861
Is it possible to set Alternative text for images in a gallery? I have looked at the manage images area and do not see a place to set alt text.
Tks
Tom
no, power gallery does not set the images alt text.
you can edit the /galleries/<selected gallery>/index.php file (where <selected gallery> is the active gallery type) and change the alt tag:
alt=""
alt="'.str_replace('"', '\"', $row_images['title']).'"
which will use the title for the alt tag
tjones368861
I have replaced the code with teh suggested code and am now getting a code error in Dreamweaver CS5.5 . here is the whol line including the revised alt code.:
<a href="<?php echo($fullsizeImgSrc); ?>" rel="lightbox-pg<?php echo($random ); ?>" name=""><img src="<?php echo($imagePath); ?>" alt="'.str_replace('"', '\"', $row_images['title']).'" title="<?php echo($i . '####'); ?>" width="<?php echo($thumbnailInfo['width']); ?>" height="<?php echo($thumbnailInfo['height']); ?>" /></a>
I can't see any problems, but dreamweaver reports code error with teh changes.
the line looks fine to me, sometimes I have Dreamweaver report an error when one does not exist. Does the gallery work in the browser? That is the true test.
tjones368861
alt tag changes
With the original code I see the following when I view source.
alt=""
when I insert the suggested code I see this when I view source:
send a copy of the page before and after editing it so i can see the code in context.
tjones368861
Code before and after
Code Before:
//gallery id, theme
if(empty($pg_id)) $pg_id = (isset($_GET['gallery']) && is_numeric($_GET['gallery'])) ? intval($_GET['gallery']) : false;
if(empty($pg_theme)) $pg_theme = 'dark';
if(isset($_GET['theme'])) $pg_theme = htmlentities(strtolower($_GET['theme']));
//set config
$abs_file = str_replace('\\', '/', dirname(realpath(__FILE__)));
$abs_prefix = substr($abs_file, 0, strrpos($abs_file, '/') + 1);
$included = strtolower(realpath(__FILE__)) != strtolower(realpath($_SERVER['SCRIPT_FILENAME']));
include($abs_prefix . 'global.php');
require_once($abs_prefix . "../webassist/caching/PG_CachedResize_Image.php" );
//get first gallery id if none specified
if(!$pg_id) {
$galleryParam = (isset($_GET['gallery'])) ? $_GET['gallery'] : "";
else{
$galleryParam = $pg_id;
$pg_id = getGalleryId($galleryParam);
$result_gallery = mysql_query('
SELECT *
FROM pg1_gallery
WHERE id = ' . $pg_id);
if(mysql_num_rows($result_gallery) == 1) {
$row_gallery = mysql_fetch_assoc($result_gallery);
else{
$row_gallery = array( 'id' => 0, 'folder_name' => '', 'title' => '' );
$pg_foldername = basename($abs_file);
$themeNames = getGalleryThemeNames($pg_foldername);
if(empty($pg_theme) || array_search($pg_theme, $themeNames) === false ){
$pg_theme = isset($_GET['theme']) ? $_GET['theme'] : $themeNames[0];
$inDesignMode = isset( $_GET['Editing'] ) ? $_GET['Editing'] : false;
if($inDesignMode){
$pg_galleryName = 'temp_editing';
else{
$pg_galleryName = $pg_foldername;
$galleries_dir = $abs_prefix;
$pg_galleryInfo = pg_getGalleryDesignThemeInfo($galleries_dir, $pg_galleryName, $pg_theme);
$themeInfo = $pg_galleryInfo['galleries'][$pg_galleryInfo['design']]['themes'][$pg_galleryInfo['theme']];
$result_images = getSyncedImagesForGallery($row_gallery);
<?php if(!$included) { ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<title><?php echo $row_gallery['title']; ?></title>
<style type="text/css" media="all">
#pgOuterWrapper .pg-rl { margin: 100px auto; }
</style>
<?php } ?>
@import url("<?php echo $pg_config['path']; ?>css/slimbox/slimbox.css");
@import url("<?php echo $pg_config['html_prefix']; ?>css/themes/gallery.php?theme=<?php echo $pg_theme; ?><?php echo ( ($inDesignMode)? '&time='.time() : '' ); ?>");
</style>
<?php if(empty($js_mootools)) { ?>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4/jquery.min.js"></script>
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>js/mootools-core-1.3.2-full-compat-yc.js"></script>
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>js/mootools-more-1.3.2.1_min.js"></script>
<?php $js_mootools = true; } ?>
<?php if(empty($js_slimbox)) { ?>
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>js/slimbox.js"></script>
<?php $js_slimbox = true; } ?>
<script type="text/javascript">var pg_thumbsPerPage = <?php echo $themeInfo['imagetypes']['thumbsPerPage']; ?></script>
<script type="text/javascript" src="<?php echo $pg_config['html_prefix']; ?>js/gallery.js"></script>
</head>
<body class="pg">
<div id="pgOuterWrapper">
<?php } ?>
<div class="pg-rl">
<!-- ribbon -->
<div class="ribbon">
<div class="prev"></div>
<div class="thumbs-wrapper">
<div class="thumbs">
<div class="thumbs-ribbon-scroller" >
if(mysql_num_rows($result_images) == 0) {
<div class="no-images">no images</div>
<?php } ?>
$random = rand(0, 10000);
$fullsizeInfo = $themeInfo['imagetypes']['fullsize'];
$thumbnailInfo = $themeInfo['imagetypes']['thumbnail'];
if(mysql_num_rows($result_images) >= 1) {
$i = 0;
while($row_images = mysql_fetch_assoc($result_images)){
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1301405982488
ob_start();
$imagePath = abs2rel( realpath($galleries_dir .'../images/' . $row_gallery['folder_name'] . '/' . $row_images['file_prefix'] . '.' . $row_images['file_ext']), getcwd());
$rotateAngle = $row_images['rotate'];
$fullsizeImgTag = '<img alt="" src="' . $imagePath . '" width="'. $fullsizeInfo['width'] . '" height="' . $fullsizeInfo['height'] .'" />'.PHP_EOL;
$watermarkOpts = array("text" => $row_gallery['watermark_text'], "font_size" => $row_gallery['watermark_font'], "position" => $row_gallery['watermark_position']);
// Note: no echo here, as we want the image resized, but we don't have an IMG tag markup in the page for the fullsize image
$fullsizeImgTag = pg_getCachedResizedImageHTML($fullsizeImgTag, "" . realpath( $galleries_dir ."../images/" . $row_gallery['folder_name'] . "/cache"), "". $fullsizeInfo['resize'] ."", "",true, false, $rotateAngle, $watermarkOpts);
if(preg_match("/src\s*=\s*(['\"])([^'\"]*)\\1/i", $fullsizeImgTag, $fullsizeMatches)){
$fullsizeImgSrc = $fullsizeMatches[2];
else{
$fullsizeImgSrc = '';
// reset watermark options for thumbnails, as they to not have watermarks on them
$watermarkOpts = array();
<div style="float:left">
<a href="<?php echo($fullsizeImgSrc); ?>" rel="lightbox-pg<?php echo($random ); ?>" name=""><img src="<?php echo($imagePath); ?>" alt="" title="<?php echo($i . '####'); ?>" width="<?php echo($thumbnailInfo['width']); ?>" height="<?php echo($thumbnailInfo['height']); ?>" /></a>
<div style="clear:left; width:<?php echo($thumbnailInfo['width']); ?>px; padding-left:10px"><strong><?php echo(str_replace('"', '\"', $row_images['title']) . (strlen($row_images['title']) > 0 ? ':' : '')); ?></strong> <?php echo( str_replace('"', '\"', $row_images['description'])); ?></div></div>
echo(pg_getCachedResizedImageHTML(ob_get_clean(), "" . realpath( $galleries_dir ."../images/" . $row_gallery['folder_name'] . "/cache"), "". $thumbnailInfo['resize'] ."", "",true, false, $rotateAngle, $watermarkOpts));
} // End Cached Resized Image: ImageCacheInstance_1301405982488
$i++;
</div>
</div>
</div>
<div class="next"></div>
</div>
</div>
</div>
</body>
</html>
<?php } ?>
tjones368861
alt text code Code After suggested change
Code After:
//gallery id, theme
//set config
if(!$pg_id) {
else{
SELECT *
FROM pg1_gallery
else{
if($inDesignMode){
else{
<head>
</style>
<?php } ?>
</style>
</head>
<body class="pg">
<?php } ?>
<div class="pg-rl">
<!-- ribbon -->
<?php } ?>
$i = 0;
ob_start();
else{
$i++;
</div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
<?php } ?>
I see, we are working from different version of the power gallery files. try changing
alt="<?php echo(str_replace('"', '\"', $row_images['title'])); ?>"
