Error sending form
Thread begun 7/19/2009 1:56 am by Daryl | Last modified 7/30/2009 1:43 pm by Jason Byrnes | 3653 views | 4 replies |
DarylBeta Tester
Error sending form
I get the following error after sending my form
  Warning: Unexpected character in input: '\' (ASCII=92) state=1 in /home/angrytec/public_html/k9-sar.com/WA_Universal_Email/WAUE_Application_Form_1.php on line 161
Parse error: syntax error, unexpected '[' in /home/angrytec/public_html/k9-sar.com/WA_Universal_Email/WAUE_Application_Form_1.php on line 161
The line in question is;
$MailBody = $MailBody . "    var accepted = \"\[^\\s\\(\\)><@,;:\\\\\\\\"\\.\\[\\]\]+\";\r\n";
The lines surrounding it are;
$MailBody = $MailBody . "  if ((!document.WAFV_Stop && !formElement.WAFV_Stop) && !(!required && value==\"\"))  {\r\n";
$MailBody = $MailBody . "    value = value.toLowerCase();\r\n";
$MailBody = $MailBody . "    var knownDomsPat = /^(com|net|org|edu|int|mil|gov|arpa|biz|aero|name|coop|info|pro|museum)$/i;\r\n";
$MailBody = $MailBody . "    var emailPat = /^(.+)@(.+)$/i;\r\n";
$MailBody = $MailBody . "    var quotedUser = \"(\\"[^\\"]*\\")\";\r\n";
$MailBody = $MailBody . "    var ipDomainPat = /^\[(\d{1,3})\.(\d{1,3})\.(\d{1,3})\.(\d{1,3})\]$/i;\r\n";
$MailBody = $MailBody . "    var section = \"(\" + accepted + \"|\" + quotedUser + \")\";\r\n";
$MailBody = $MailBody . "    var userPat = new RegExp(\"^\" + section + \"(\\.\" + section + \")*$\");\r\n";
DarylBeta Tester
After I changed all the checkboxes for radio buttons it seems to have resolved...?
DarylBeta Tester
The problem is back now;
Warning: Unexpected character in input: '\' (ASCII=92) state=1 in /home/angrytec/public_html/k9-sar.com/WA_Universal_Email/WAUE_Application_Form_1.php on line 163
Parse error: syntax error, unexpected '[' in /home/angrytec/public_html/k9-sar.com/WA_Universal_Email/WAUE_Application_Form_1.php on line 163
DarylBeta Tester
The problem was that when I copied the form over for the body of the email it copied the validation over too - this was what was causing the problems.
It's best not to copy the forms code over.
Instead, on the body tab of Universal Email, clic krthe DW Edit button to use Dreamweaver to Look of your email.
Where you wish to display the form output, go to the bindings panel, expand the Form Collection and bind the appropriate form element.
