Minimum quantity in detail, results and cart pages.
Thread begun 1/03/2012 11:02 am by bill3786 | Last modified 1/05/2012 8:42 am by bill3786 | 2737 views | 5 replies |
bill3786
I need to set a minimum quantity of 2 to show on the "add to cart" area of the results and detail pages for the whole product range.
How is this best achieved and also how can I prevent a customer reducing the quantity from 2 to 1 in the cart before checkout?
in the eCart object, create a new calculation on the calculations tab as:
setQuantity
abs([Quantity] < 2)?[Quantity] = 2:''
this calculation will force the quantity to 2 if it is set to something lower.
in the add to cart button form, you can change the initial value of the quantity text box to 2.
bill3786
Thanks, works a treat.
bill3786
Is it possible to add a tooltip or popup message when a visitor attempts to reduce the quantity below 2.
you would need to add an onchange event to the quantity text field:
onChange="if(isNaN(this.value) || parseInt(this.value) < 2) {alert('Quantity cannot be less than 2'); this.value = 2;}"
bill3786
Thanks, works a treat again.
