Change password page problem!
Thread begun 1/01/2012 2:41 am by steelace396915 | Last modified 1/04/2012 8:43 am by steelace396915 | 3196 views | 5 replies |
steelace396915
I have built a set of SecurityAssist pages from wizard and got almost everything working. I have one major problem though!
The change/update password page works in general but it does not prevent inserting a not registered email address in database. For example, a user who is registered can change his password through the change password page process but if he inserts an incorrect email address it too changes in database along with the new password!?? Of course I dont want that to happen. How do I restrict a user from changing his password if the email entered in change password page is not registered for that user in database!?
Please help!
Regards,
Martin J.
you can edit the update record behavior on the new password page and remove the binding for the email address column so that the email address cannot be changed.
steelace396915
Thanks Jason! I don't understand that I could not figure that out myself!? lol Sometimes the "computer" gets overloaded! ;=)
steelace396915
One more (maybe stupid) question! If I want to remove the email formfield from the reset password section in the forgetpassword page (page/section where the user reset the password after clicking the link in email messege) what do I remove in the server behaviours panel? I did remove the binding in the update server behaviour so the email dont update whatever the user puts in so its no need to keep the email field at all. Ive tried to hide it but that didn't work.?
Martin J.
in addition to deleting the form element, you will need to delete the following code at line 32 -33:
$WAFV_Errors .= WAValidateEM((isset($_POST["Reset_Password_group_E_post"])?$_POST["Reset_Password_group_E_post"]:"") . "",true,1);
  $WAFV_Errors .= WAValidateUnique("mydatabase_se",$mydatabase_se,$database_mydatabase_se,"member","MemberID","none,none,NULL","".((isset($_GET["fp_id"]))?$_GET["fp_id"]:"0")  ."","MemberEmail","',none,''","".((isset($_POST["Reset_Password_group_E_post"]))?$_POST["Reset_Password_group_E_post"]:"")  ."",true,2);
steelace396915
Thanks a lot Jason! That took care of the problem! Really appreciate your help!
/Martin J.
