Success Notification Using Show Region
Thread began 12/29/2011 2:20 pm by mora398588 | Last modified 1/03/2012 12:01 pm by mora398588 | 1653 views | 8 replies |
mora398588
I would like to use SA show region feature to show a "success notification" image when a user updates there user profile.
I have attempted to create a new rule for this function in SA, but I am a little stumped as to how to go by it. The page uses an "update" button that updates the users contact info in a sql database.
Here is the rule I attempted to create in SA:
case "Success Notification UserProfile":
$comparisons[0] = array(TRUE, "".((isset($_POST["Update"]))?$_POST["Update"]:"") ."", 1, "true");
break;
I have attached my file for your review. Could you review my page and provide any assistance?
Thank you.
users_Profile.zip
in the insert record behavior, set the success redirect to pass a querystring variable to the profile page:
users_Profile.php?updated=true
go to the bindings panel, click the plus button and select URL Variable, name it "updated"
now create your security assist rule to use the "updated" query string variable instead of the POST variable.
mora398588
Jason, thank you for your reply.
I followed your directions to the best of my ability and I was unable to get the show region to work. I noticed in your reply that you mentioned the "insert record behavior.' I was unable to locate such a behavior. However, I did find an 'update record behavior.' This was the behavior I used to insert the query string variable. Please reference the attachment of my users_profile file which reflects the changes I recently made.
Here is the SA rule that I created...
$comparisons[0] = array(TRUE, "".$_GET['updated'] ."?updated", 1, "true");
break;
Please note that I have been uploading the SA 'Helper_PHP' and the 'HelperGroupsRulesPHP' files to my server when I modifying the SA Access Rules.
Thank you for your continued assistance.
users_Profile.zip
are you hand coding this? ou should create the rule in the access rules manager not by hand coding it, the code for this rule looks completely wrong.
in the access rules manager, click the lightning bolt next to value and select the "updated" querystring variable. set the Criteria to "=", for the comparison enter "true"
mora398588
Hello, Jason.
The code I provided was taken out of the 'HelperGroupsRulesPHP' files located in my webassist directory.
I thought by showing you the code, you may see what SA Access Rules Manager is creating. I did not hand code the access rule. I used SA Access Rules Manger to create the rule.
The instructions you provided in your last reply was the exact process I used to create the rule.
Does this clarify thinks?
this line:
should be:
$comparisons[0] = array(TRUE, "".((isset($_GET['updated']))?$_GET['updated']:"") ."", 1, "true");
mora398588
Should I insert this updated line of code in the 'HelperGroupsRulesPHP' file in webassist directory?
yes, in the webassist/helpergroupsrulesphp.php file, change:
yo:
mora398588
That's it.
The code apparently was the issue. Thank you so much.
I appreciate your help...as always!
