Changing Quantity "get" section
Thread begun 12/29/2011 12:54 pm by sandy259886 | Last modified 12/30/2011 3:43 pm by sandy259886 | 1788 views | 4 replies |
sandy259886
I have a repeated region with add to cart button on each row of each repeated region section. I have the quantity field named: "quantity_(productID from recordset) I need to update the add to cart server behavior with the correct name for the quantity field.
Specifically, I want to change this row:
$ATC_itemQuantity = "".$_POST["pfgbest_1_Quantity_Add"] ."";// column binding
so that it references the new field name:
quantity_<?php echo $row_rsAssocFormats['PKey']; ?>
HOW DO I DO THAT?
Below is my repeat region form
<?php do { ?>
$paramAssocProd_rsAssocFormats = "-1";
if (isset($row_rsAssociation['assocprod'])) {
$paramAssocProd_rsAssocFormats = (get_magic_quotes_gpc()) ? $row_rsAssociation['assocprod'] : addslashes($row_rsAssociation['assocprod']);
mysql_select_db($database_traders, $traders);
$query_rsAssocFormats = sprintf("SELECT * FROM prod WHERE PKey = %s", GetSQLValueString($paramAssocProd_rsAssocFormats, "int"));
$rsAssocFormats = mysql_query($query_rsAssocFormats, $traders) or die(mysql_error());
$row_rsAssocFormats = mysql_fetch_assoc($rsAssocFormats);
$totalRows_rsAssocFormats = mysql_num_rows($rsAssocFormats);
<tr>
<td width="300"><?php echo $row_rsAssocFormats['Format']; ?>
</td>
<td width="55"><?php echo $row_rsAssocFormats['PriceCalc']; ?></td>
<td>
<form name="pfgbest_1_ATC_<?php echo $row_rsAssocFormats["PKey"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="text" name="quantity_<?php echo $row_rsAssocFormats['PKey']; ?>" value="1" size="4" >
<input type="submit" class="eC_FormButton" value="Add to Cart" name="pfgbest_1_ATC">
</form>
</td>
<td></td>
</tr>
<?php } while ($row_rsAssociation = mysql_fetch_assoc($rsAssociation)); ?>
Below is what the entire add to cart server behavior looks like:
// WA eCart AddToCart
if (isset($_POST["pfgbest_1_ATC"]) || isset($_POST["pfgbest_1_ATC_x"])) {
$ATC_itemID = $_POST["pfgbest_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "ssl/checkout/shoppingcart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsAssocFormats) && $totalRows_rsAssocFormats > 0) {
$row_rsAssocFormats = WAEC_findRecordMySQL($rsAssocFormats, "PKey", $ATC_itemID);
if ($row_rsAssocFormats) {
$ATC_itemName = "".$row_rsAssocFormats['Title'] ."";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("".$row_rsAssocFormats['ShipWtFactor'] ."");// column binding
$ATC_itemPrice = floatval("".$row_rsAssocFormats['PriceCalc'] ."");// column binding
$ATC_itemItemnumber = "".$row_rsAssocFormats['itemNumber'] ."";// column binding
$ATC_itemRetail = floatval("".$row_rsAssocFormats['RetailPrice'] ."");// column binding
$ATC_itemFreeitems = "";// column binding
$ATC_itemBundleitems = "";// column binding
$ATC_itemEbooklink = "".$row_rsAssocFormats['EbookLink'] ."";// column binding
$ATC_itemAllocate = "0";// column binding
$ATC_itemInventoryOnHand = "0";// column binding
$ATC_itemBackorder = "0";// column binding
$ATC_itemapplyDiscount = "0";// column binding
$ATC_itemDiscount = floatval("0");// column binding
$ATC_itemmp3link = "".$row_rsAssocFormats['mp3link'] ."";// column binding
$ATC_itemsendEmail = "".$row_rsAssocFormats['sendEmail'] ."";// column binding
$ATC_itemmediaPage = "".$row_rsAssocFormats['mediaFilePath'] ."";// column binding
$ATC_itemBooksInCart = "".$row_rsAssocFormats['BooksinCart'] ."";// column binding
$ATC_itemDiscountablePrice = floatval("".$row_rsAssocFormats['DiscountablePrice'] ."");// column binding
$ATC_itemItemDiscounts = floatval("0");// column binding
$ATC_itemQualifiedPennyPick = "".$row_rsAffiliates[''] ."";// column binding
mysql_data_seek($rsAssocFormats, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$pfgbest->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemItemnumber, $ATC_itemRetail, $ATC_itemFreeitems, $ATC_itemBundleitems, $ATC_itemEbooklink, $ATC_itemAllocate, $ATC_itemInventoryOnHand, $ATC_itemBackorder, $ATC_itemapplyDiscount, $ATC_itemDiscount, $ATC_itemmp3link, $ATC_itemsendEmail, $ATC_itemmediaPage, $ATC_itemBooksInCart, $ATC_itemDiscountablePrice, $ATC_itemItemDiscounts, $ATC_itemQualifiedPennyPick);
if ($ATC_RedirectAfter != "" && $pfgbest->redirStr == "") {
$pfgbest->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
since each of the quantity elements and submit buttons are in there own form tags, there is no need to use unique naming for the elements.
When a submit button on your page is pressed, only the quantity element that is inside the same set for <form...>....</form> tags will be sent, you can name each quantity element the same, "pfgbest_1_Quantity_Add", and not worry about changing the name.
sandy259886
can't get it to work
The file is live at:
detail.php?PKey=824
When I add one of the items to the cart, I get this message:
Undefined variable: ATC_itemQuantity in /home/tradertest/public_html/detail.php on line 418
I've attached the file for your review.
the problem is that the recordset you are using for the add to cart button is in the body of the page inside a repeat region, it does not exist when the add to cart button code is running.
create another recordset that that queries the products table, and use that recordset for the bindings in the add to cart button behavior.
sandy259886
Duh
Got it fixed. Thanks for the heads up. I apparently had a brain fart.
