crashing..
Thread begun 12/24/2011 7:50 am by wbrooks199805 | Last modified 12/27/2011 12:15 pm by Jason Byrnes | 1235 views | 1 replies |
wbrooks199805
crashing..
The client error logs are having issues with connections to 'Power Store' which seem to coincide with the crashes as logged below, seems to be an issue in the connection on line 9 for PowerStore and line 11 for the localhost in the php code. Can you help?
[Thu Dec 15 04:59:24 2011] [error] [client 180.76.6.29] PHP Warning: mysql_pconnect(): Can't connect to MySQL server on 'enhancedhealing' (105) in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Thu Dec 15 05:03:47 2011] [error] [client 66.249.72.11] PHP Fatal error: in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Thu Dec 22 11:03:14 2011] [error] [client 140.203.155.8] PHP Warning: mysql_pconnect(): Can't connect to MySQL server on 'enhancedhealing' (105) in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Thu Dec 22 11:03:14 2011] [error] [client 140.203.155.8] PHP Fatal error: in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Sat Dec 24 00:13:48 2011] [error] [client 70.32.108.107] PHP Warning: mysql_pconnect(): Lost connection to MySQL server at 'reading initial communication packet', system error: 111 in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Sat Dec 24 00:13:48 2011] [error] [client 70.32.108.107] PHP Fatal error: Lost connection to MySQL server at 'reading initial communication packet', system error: 111 in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/PowerStoreConnection.php on line 9
[Sat Dec 24 00:13:50 2011] [error] [client 180.76.5.160] PHP Warning: mysql_pconnect(): Link to server lost, unable to reconnect in /var/www/vhosts/enhancedhealing.com/httpdocs/Connections/localhost.php on line 11
