Custom behaviors delete when modifying form
Thread begun 12/23/2011 11:29 am by fxs430566 | Last modified 12/29/2011 8:56 am by Jason Byrnes | 2184 views | 3 replies |
fxs430566
How is it that everytime I modify and existing form the custom server behavior in WA server validations gets deleted?
Validation Type "Like Entry" gets deleted, along with the Validation Show If.
Why is that?
when you edit the form in css form builder it recreates the form from scratch, any validations you add outside of the form builder wizard will be removed since the form builder wizard does not know about them.
If you are going to edit the form, make sure you define the validations inside the for builder wizard.
fxs430566
How do I save Server Behaviors in the Form Builder Wizard?
in the form builder wizard, you need to define the fields that will have validations applied to them so you will not need to create another validation show if or server validation after the form is created.
