how to handle multiple prices levels in eCart
Thread begun 12/22/2011 6:49 am by bhblake | Last modified 12/22/2011 1:14 pm by Jason Byrnes | 1607 views | 1 replies |
bhblake
I'm developing a site that has three price tiers - Retail, Wholesale, and designer. These prices are all set up as separate fields in my products table. My question is how do i handle it when it comes to eCart. I have used security assist and have 3 tiers of logins and depending on what you login tier is you will only see the price for you tier, however how should I go about handling the price column in eCart so the the 3 different fields funnel into the same price column depending on your login.
Thanks.
you will need to add custom code for this
in the addd to cart button code, you will need to add the same if statements around the price code, as you do to display the price, based on the userlevel session.
for example the code for the price column in the add to car may look like:
[php]$ATC_itemPrice = floatval("".$row_recordsetName['ProductPrice'] ."");// column binding:[php]
you would need to use an if statement around that code:
if($_SESSION['userlevel'] == "1") {
} elseif($_SESSION['userlevel'] == "2") {
$ATC_itemPrice = floatval("".$row_recordsetName['ProductPrice2']  ."");// column binding
} elseif($_SESSION['userlevel'] == "3") {
$ATC_itemPrice = floatval("".$row_recordsetName['ProductPrice3']  ."");// column binding
