change captcha font and colours
Thread begun 12/22/2011 5:44 am by asnw0764437428 | Last modified 12/22/2011 1:31 pm by asnw0764437428 | 15905 views | 2 replies |
asnw0764437428
Hi
Used CSS Form Builder to add the necessary captcha security code to implement into an already designed form not done via CSSFB
I have deleted the page that was originally created and didn't realise that the colours and font may need changing. From the pages created by CCFB, which one do I need to edit to make the changes and on which lines. I must admit I was use to the WAGlobals file for doing this previously.
After a bit of quick reading I realised that CSSFB will edit an externally designed form. I have just tried this and noticed that the edit button associated with the security captcha section is greyed out. Remembering back to when I originally did the captcha is was greyed out then also. So the captcha cannot have further editing in the form of font colour, background noise etc.
So still back to my original question of what pages and lines I will need to manually edit to make changes etc.
Many thanks.
Im not sure which edit button your are referring to, but i don't think it is the right one.
when you select the form tag in design view, the property inspector will show 3 buttons:
Edit Form
Edit Design
Edit Contents
to change the look of the captcha element, click the Edit Design Button (or click Edit Form then Customize CSS)
in the Edit Design window, change the initial select list to Form Elements, then in the secondary select list choose Captcha. This window will allow you to edit the look of the captcha image.
asnw0764437428
captcha fonts and colours
Hi
Thanks for the reply. Always jumping right in and not paying any attention to reading things. Thanks I managed to edit the actual code relating to changing font and colours etc. But will remember for next time. Just used to the old download where WAGlobal was involved before CSSFormBuilder was around.
Many thanks
Have a good christmas!
