Multipled Cart Storage - Retrieve & Continue Later
Thread begun 12/20/2011 4:58 pm by codamedia | Last modified 12/22/2011 3:06 pm by codamedia | 4429 views | 2 replies |
codamedia
I have a client that would like their users to be able to save a cart, then retrieve it later to continue shopping. To compound this - they would like the user to be able to save several different carts, not just one.
Attaching a USER ID with the stored carts will not be an issue (so each logged in user can only see their stored carts), but I am not sure how I would go about storing/retrieving the cart itself for later editing and use.
If someone could point me to the documentation on how to do this I would appreciate it.
there is no documentation for doing this that I can point you to.
you would need to create 2 tables in your database.
the first table will have a primary key column, another column to store the ID of the logged in user, and a text column to store a name for the saved cart.
the second table will have a primary key column, a column that relates the ID column from the first table and additional columns for each of the columns in your eCart object. for example:
cart:
cartID - primary key
cartUser - relates to user.userID
cartName
cartdetails:
cartdetailID - primary key
cartdetailcartID -relates to cart.cartID
cartdetailProductID - stores the ID column of the cart
cartdetailProductName - stores the name column from the cart
etc...
on the page that you add the Save Cart button, add a textfield to set the name of the cart.
then use the eCart Store Order Summary behavior to create a new record in the cart table for the order. bind the cartUser column to the user ID session variable, bind the cartName column to the text field. set the OrderID column to use the primary key cartID column and make note of the name that is set in the Store As section.
Next add the eCart Store order Details behavior. Set the Order ID to use the cartdetailCartID column, bind that column to the session variable created by the Store Oder Summary behavior.
Bind each of the additional columns to the corresponding column in the cart object.
You now need to create a page to show a listing of the saved cart. use recordset that queries the cart table and filters the cartUser column on the users ID.
use a repeat region to show the cart name for each record returned. use the cart name as a link to a page that will populate the cart with the corresponding items by passing the cartID as a querystring variable
on the page that will populate the cart, create another recordset that will query the cartdetails table, filter the cart details table using the cartID querystring variable.
on the server behaviors panel, click the plus button and select eCart -> Add to cart -> Get Contents from recordset to use the recordset to repopulate the cart.
codamedia
Jason,
With replies like yours who needs documentation :)
That is incredibily detailed, and will certainly get me going on this.
Thank you for this information!
Maggie Simpson
Add to cart using "Get contents from recordset"
I also am using this method to repopulate a cart based on a recordset query, filtered by a unique ID...
On my page that will populate the cart, I have defined all of the column bindings, etc, in much the same way the columns are bound when creating a typical add to cart button, but I am stuck there. I defined my trigger as "on page submit" so will a form with a page submit button repopulate my cart with the filtered results? Thank you in advance...
Am I perhaps using the wrong trigger? Should I be using the "if selected cart is empty" trigger?
the trigger should be on page load.
Maggie Simpson
This post has been deleted.
the code snippet is not enough to troubleshoot by. please send a copy of the page so i can see the code in context.
Maggie Simpson
Attached is the file, thanks
try adding this line just before the doctype tag:
$eCart1
->GetContent();
Maggie Simpson
Still no go... sorry
