mysql
Thread begun 7/18/2009 1:43 am by i.edwards384429 | Last modified 7/20/2009 7:41 am by Ray Borduin | 2091 views | 1 replies |
i.edwards384429
mysql
Hi
Ok no doubt an idiot question but .....
Just bought the essentials suite for a project and I'm a little confused. Can someone just clarify a few points for me?
I assume that I have to manually create the mysql database and setup the connection for Dreamweaver before I can use any of the suite extensions?
As my exoerience with mysql is - close to zero is it worth me getting the solution pack for both the tutorials and the ready made databases?
My project is based on searching the database for specific criteria which will result in a list of contact emails, the site will need a user registration sequence, a search sequence and finally a means by which payment for the email addresses should be made.
This should I assume from my experiecne with readymade options be in one database?
So which should I start with? My thoughts are to but the tutorial pack and use the digital delevery database as a starting point
Really would appreciate some input
thanks
Ian
I would start by getting the "database starter kit" to help you install and understand how databases work with Dreamweaver in general.
Then you would create your database. I would go through the tutorials for SecurityAssist, DataAssist, and eCart based on your application at least those will be used.
If you want a starting point you should maybe get the user registration solution... it will give you a head start on what you are developing.
