List values in relation to price variants . . .
Thread begun 7/17/2009 6:17 pm by wetware | Last modified 7/20/2009 7:01 am by wetware | 9362 views | 14 replies |
wetware
Kid's Life Vests - three (3) "Sizes" ("Size" column in eCart Object). Infant is $20/ea.; Child & Youth are $17/ea. As of now, the "Value" (below) shows up in the Shopping Cart under "Size" (which is desired), but the prices need to be translated separately into the "Price" column individually (Add to Cart "Price" default is now set to $20).
Here's the existing code in the "Form" area:
<input type="hidden" name="eCart1_1_ID_Add" value="0" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<select name="eCart1_1_Size_Add">
<option value="Size" selected="selected">Select Size</option>
<option value="Infant">Infant</option>
<option value="Child">Child</option>
<option value="Youth">Youth</option>
</select>
Thanks in advance . . .
bjgarner241692
You need a database
But you can probably make this work if you put the price in the VALUE part of your Select List and then set Price to the Select field in your Add to Cart Behaviour.
Storing this info in a db will make your management of the data much easier in the future and it makes working with eCart easier too.
wetware
Echoing the Value field . . .
. . . the "Value" field is what is shown in the "Size" column in the Shopping Cart - it's necessary to show the "Size", not the price there.
Of course, I don't know what is meant by "set the Price to the Select field". I'm attempting to understand the theories of PHP, but . . .
CraigRBeta Tester
Not sure if I understand correctly, but..
could you not concatenate the size and price in the dropdown as the 'label' and the price as the 'value' ?
or if you have a url I may understand better.
wetware
Hi there . . .
. . . concatenate is something I've read/seen, but applying it here is another kettle of fish. It's used to put two string values together(?), but I do not know how that applies here . . .
The page in question is:
TWF_Product_RevereDetail-002.php
Everything rolls through fine, as long as the price for each of the three (3) selections in the list are the same (default Price in Add to Cart bindings being $20, or whatever). But, the Shopping Cart needs to continue to display the text description in the "Size" column, while translating the price differences to the "Price" column.
I am unable to achieve this, because (mainly) I do not know/understand how to construct, let alone place, the PHP in the page . . .
The following may/may not be part way there:
$Infant-20;
$Child=17;
$Youth=17;
Thanks again for taking the time!
CraigRBeta Tester
retrieve list/menu label value ?
Ok, ignore the concatenate thing for now, it is generally cosmetic.
what i think you are trying to achieve is have a list/menu in your add to cart form, having the price as the value and the size as the label.
when you submit the form, you want to retrieve both the selected size AND the price, to pass into your cart.
I have done this with a javascript function before, but my javascript isn't my strong point. I think Ray Borduin showed me the syntax a while ago.
if this looks like the thing, i'll take a proper look.
regards
wetware
Hi there!
Yeah, mon - price as the value and the size as the label . . .
These days the only thing that I specialize in is re-reading others' posts & trying to adapt. I'm an old prepress operator who has a design biz & is trying to tie together some programming skills.
Thanks, again . . .
CraigRBeta Tester
try this...
You need to store the label string value as a hidden field in the add to cart form, setting a default value, (this value is only updated onchange in this example).
eg <input type="hidden" name="label" value="Small" >
In this example, the list/menu is called listsize and calls a js function called 'getlabelstring' as follows....
<select name="listsize" onchange="getlabelstring()">
<option value="10">Small</option>
<option value="20">Medium</option>
<option value="30">Large</option>
</select>
the javascript function to retrieve the list label should go in the head section of your page.
the function has the general structure as below, just substitute the formname, listbox name and hidden fields accordingly
document.formname.label.value=document.formname.listbox.options[document.formname.listbox.selectedIndex].text
in this example, my add to cart form is called gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?> the listbox is called listsize, the label is called label, so the function is like this...
/* <![CDATA[ */
function getlabelstring(){
document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.label.value = document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.listsize.options[document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.listsize.selectedIndex].text;
</script>
now set the size in the add to cart behavior... $ATC_itemSize = "".$_POST["label"] ."";// column binding#
if you wish to display the price as well as the size in the list label, eg
<option value="10">Small ($10.00)</option>
<option value="20">Medium ($20.00)</option>
<option value="30">Large ($30.00)</option>
</select>
you would need to do some string manipulation to extract the appropriate substring from the label.
eg to extract all characters until the space
/* <![CDATA[ */
var firstbit = document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.listsize.options[document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.listsize.selectedIndex].text;
firstbit = firstbit.split(" ");
document.gallerybasket_1_ATC_<?php echo $row_rsdetail["ID"]; ?>.label.value = firstbit[0];
</script>
(I haven't tested this if js is disabled, the price will still calculate ok, but I presume that the size info from the label will not.)
wetware
Wow!
It's gonna take a second (study & implement), but I'll get back to you with results!
Thanks, man . . .
wetware
Results . . .
. . . with the following code:
•HTML head:
/* <![CDATA[ */
document.eCart1_1_ATC_0<?php echo $row_rsdetail["ID"]; ?>.label.value = document.eCart1_1_ATC_0<?php echo $row_rsdetail["ID"]; ?>.listsize.options[document.eCart1_1_ATC_0<?php echo $row_rsdetail["ID"]; ?>.listsize.selectedIndex].text;
</script>
•HTML body:
<!--storing label string value in a hidden field in the Add to Cart form - this value is only updated onchange
<input type="hidden" name="label" value="Select Size" >
<!--list/menu is called listsize and calls a js function called getlabelstring
<option selected="selected">Select Size</option>
<option value="20">Infant</option>
<option value="17">Child</option>
<option value="17">Youth</option>
</select>
•Add to Cart "Size" binding (default value):
<?php echo $_POST["eCart1_1_Size_Add"]; ?>
•Live Result:
The "Size" column is displayed correctly (Infant, Child, or Youth) but the "Price" column says "0" . . .
I'm thinking that a javascript term is used incorrectly?
