running database across 2 xampp installs
Thread begun 12/15/2011 5:30 am by JamieEff | Last modified 12/16/2011 2:54 am by JamieEff | 2099 views | 3 replies |
JamieEff
Hi guys
Am trying to set up PowerCMS on XAMPP for a website that has been set up successfully on one machine...
But on the other machine when I go to the localhost/abc/ to view the same site i get the following error:
Warning: require_once(../images/installed.png) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\sewards\WA_Globals\WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.png' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\sewards\WA_Globals\WA_Globals.php on line 60
Obviously done something wrong... just not sure what!
Thanks in advance
Jamie
JamieEff
have actually managed to figure this one out... and its working fine now
But it has raised another question for me...
With a setup of having localhost (testing server) and the main files in another area (local), if i make changes to the database on the testing, how would you synchronise those database changes/updates from testing to local?
I have had a 'play' with the synchronise button on the DW files window, but dont seem to be getting it right... any help or pointers gratefully received
Many thanks
Jamie
you would need to export the data from one database, then import it to the other database in order to synch them. There is no automated way to accomplish this.
JamieEff
thanks Jason
