All Records disappear with pro maps
Thread begun 12/14/2011 6:35 am by Jedi | Last modified 12/16/2011 3:53 am by Jedi | 4278 views | 7 replies |
Jedi
Hi, I have a page that has three different recordsets on it. They are all in show if regions. Everything works fine until I try to add a pro map into any of the records. When I add pro maps then nothing at all shows up. I have a check for all errors code on the page and it returns no errors.
please send a link where i can see the problem, a copy of the page and the google_javascript folder in a zip archive so i can examine the code.
Jedi
Thanks for your help Jason.
Here is the link to the page: print_Coupons1.php?CouponID=14
and I have included the files in the zip folder
looks like the copy of the google_javascript/wagmp_maps.js file on your server is an old version that does not contain a reference for the map on your page. update the google_javascript/wagmp_maps.js file on the server with the most recent one from your local site
Jedi
Thanks Jason, that took care of the google maps but why do you think the other data in the recordset isn't showing up?
add the following code just after the <body> tag on your page:
mysql_data_seek
($rsCoupon0);
$row_rsCoupon mysql_fetch_assoc($rsCoupon);
Jedi
HiJason, Thanks for your help. It is working now. What I found out was that after I put the map in and when I put in the repeat region that the map also put the repeat region in as well. I saw this on the javascript page. I installed another map and all works well now.
Again, thanks for the help.
Jedi
I have two more questions/issues. The first is with form validation on this page. I have set up a form on the page with the 3 hidden regions. The form is using web assist client validation and it doesn't seem to validate the form.
The second question is....Can one use their own default image for google pro maps? And, if so, how do I change the google default to point to mine?
