Button Not In Centered with Text Field
Thread begun 12/13/2011 5:16 pm by mora398588 | Last modified 2/03/2012 6:28 am by bill3786 | 5759 views | 14 replies |
mora398588
I inserted a dynamic 'add to cart' button to my details.php page. When the button was added with a quantity text field, the button appears to not center with the text field. In fact, it is at an angle or slightly higher than the text field.
I attempted to correct this issue by adjusting the button (image) placement, such as top, left, right, center, etc...
After selecting the placement option that would seem to work, the button did not correct itself. It is still slightly off center. Is there a way to correct this or should I use a form button in place of it?
it is impossible to give advice on design issues like this without being able to see it in a browser.
please post a link where i can see the problem.
mora398588
I am sorry about that. I am sending you the link to my Results page. From there you can click on any of our products/classes to see the Details page where the problem is located.
I am also sending you a copy of the Details page file.
Thank you.
presentations_Results.php
in the style section of your details page, add the following new style:
.eC_ImageButton {
vertical-align: bottom;
mora398588
Jason,
thank you for the css code. It worked great.
Appreciate your help!
bill3786
I have the same problem on my detail and results page. Will the new style work in any dataassist results and detail page which have the ecart Add to Cart button or is it specifically for mora398588?
it should work, if not, send a link and i'll look into it.
bill3786
I've tried it and it doesnt make any difference. My site is not live so I've included screenshots of the detail and results page. Is this sufficient?
change it to:
.WADADetailsButton {
bill3786
I've tried the style you suggest but no difference, in fact the ideal solution would be to align the quantity box with the top of the cart button. Tried top, middle and bottom in the style and the quantity box doesnt move!!
