Images will not appear if in sub folder
Thread begun 12/13/2011 11:22 am by CUAD | Last modified 7/18/2013 1:47 pm by Jason Byrnes | 6424 views | 14 replies |
CUAD
I have installed the new HTML editor and when I upload images to the root folder they appear fine. But when I upload them to a sub folder they tend to not show up. In the source link it does not insert the / after the folder. See image attached for example. How can I get it to show the / there regardless? There should be a / after the word posts.
It should look like this:
/elements/images/posts/Steve/test/Fotolia_14001911_XS.jpg
Instead it is looking like this:
/elements/images/postsSteve/test/Fotolia_14001911_XS.jpg
in the webassist/kfm/configuration.php file, what is the $kfm_userfiles_address set to?
CUAD
It is set at
$kfm_userfiles_address = '../../elements/images/posts';
If I insert a dash after posts it show images just fine if in sub folder but then will insert two // in root folder.
Web Designer Troy
Similar issue
I'm using GoDaday and a maked subdirectory where the subdirectory has its own doman name. (i.e. subdiretory/ is now subdirectory.com).
How do I upload images so that the images' paths reference www.subdirectory.com and not /maindomain.com/subdirectory/ through where they will not work?
CUAD
I am having this same issue with the files not getting inserted right. If the files are in a sub directory then the file will not have a / in between the root and sub folder. If in the sub folder it works fine. The $kfm_userfiles_address = ../../elements/uploadFiles and I cannot add a / at the end to fix issue.
CUAD
Please see private area
i updated the webassist/kfm/filebrowse.js js file on your server and changed the user file path to:
$kfm_userfiles_address = '../../elements/uploadFiles/';
