Control fields
Thread begun 12/12/2011 6:16 pm by brian432984 | Last modified 12/14/2011 8:23 am by Jason Byrnes | 1720 views | 2 replies |
brian432984
Control fields
I want to make a form that fits in a narrow column, 200px.
I cannot work out how to control the elements to do this.
1. I want the field name above the input element. It is just too narrow to have these two items side by side.
2. I need to control the width of the input element (other than small, large etc).
Can I do this?
brian432984
Forgot to mention, I am creating a basic contact form
in the css form builder wizard, click on "Customize CSS".
from the initial list, select "Form Elements", the select "Element Labels". Here you can set the Placement of labels to Top and the Alignment of the labels to Left.
for setting the width, you will need to select the "Form" option from the initial list and set the width for the form, then select "Form Elements" -> "Text" to set the width that will be used for the small medium and large text boxes.
select any other element types you will use in your form to set the widths for those as well.
