Can't change Write Permissions with GoDaddy
Thread begun 12/12/2011 8:44 am by readyross433225 | Last modified 12/12/2011 6:37 pm by Matthew Meling | 11803 views | 4 replies |
readyross433225
Uploaded PS4 through Dreamweaver to my GoDaddy server. I can't seem to find where I can change the permissions to 777? I tried to change it through Dreamweaver but it just says that it cant grant the change bc of the server. Any ideas on this? thanks
DougBBeta Tester
I use GoDaddy aswell,
if you go into the FTP file manager on GoDaddy, you can manually change permissions.
However if you want to make changes dynamically in PHP.. I use a small routine listed below that works wonders. I do this in Powerstore during my uploads. Just change the parameters in the function to set permissions if you need a PHP solution otherwise do it manually with the FTP manager
Hope this helps...
chmod_R($path1, 0666,0777);
// provide security for files/paths
function chmod_R($path, $filemode, $dirmode) {
if (is_dir($path) ) {
if (!chmod($path, $dirmode)) {
$dirmode_str=decoct($dirmode);
print "Failed applying filemode '$dirmode_str' on directory '$path'\n";
print " `-> the directory '$path' will be skipped from recursive chmod\n";
return;
$dh = opendir($path);
while (($file = readdir($dh)) !== false) {
if($file != '.' && $file != '..') { // skip self and parent pointing directories
$fullpath = $path.'/'.$file;
chmod_R($fullpath, $filemode,$dirmode);
closedir($dh);
} else {
if (is_link($path)) {
print "link '$path' is skipped\n";
return;
if (!chmod($path, $filemode)) {
$filemode_str=decoct($filemode);
print "Failed applying filemode '$filemode_str' on file '$path'\n";
return;
Matthew Meling
Thanks for the assist Doug!
Readyross, like Doug said, you should easily be able to change the permissions through FTP. If you need more help with the process, please let us know.
readyross433225
thanks!!!
Thanks, it worked great
Matthew Meling
No problem. Any more questions, please don't hesitate to ask.
