checkbox multi insert only adds last item
i have played around with this for ages, started again a couple of times, but only the last selected item is ever inserted into my table.
I stripped the page down to its base elements, but same result.
Its been a while since I did this.
I forgot that the wizard often puts the repeat selection iterator outside of the do.. loop
Hopefully DA3 will finally fix this
Hey Craig,
Nice catch there. I'll make sure the engineers know about this issue so we can get it fixed.
Thanks. Have a great evening
