Ip Address!!
Thread begun 12/07/2011 5:36 am by Kumel | Last modified 12/26/2011 1:52 am by kumel619425561 | 7192 views | 19 replies |
Kumel
Ip Address!!
I had inserted security assist pages except UPDATEPAGE.PHP..
When a new user register's how do we store the ipaddress of the user in DB...? The field is already there in DB, but no values..!
Its urgent please help.
in the registration page, edit the insert record behavior. Select the ip address column and click the lightning bolt icon next to value. From the bindings panel expand the server collection and select the remote address binding.
Kumel
thats cool.. how about in update page? like a user upload a image. then it must store the IP address while uploading too.. i did the same method. but the field value is BLANK.. What do i do?
on the profile page, edit the update record behavior. Select the ip address column and click the lightning bolt icon next to value. From the bindings panel expand the server collection and select the remote address binding.
Kumel
edit the update record behavior.???????????????
Its not a update record page..
Its just a page where it insert's record in DB.. i have attached the file please check..
All the records are getting added but not the IP.
to help troubleshoot, change line 154:
$WA_redirectURL = "SnapsDetails.php";
$WA_redirectURL = "";
then add the following code just after the <body> tag to output the SQL Insert Record command:
<?php echo("IP: ". (isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"N/A"."<br />SQL: ".$WA_Sql); ?>
post back the results after trying an insert.
Kumel
Nah! Not working.. page is showing but still its the same.. Only IP ADDRESS IS shown in the page.. after clicking "upload" the values are not inserting in DB
i did not say adding that code would fix the problem, i said it would help me troubleshoot the probelm by outputting the insert SQL to the page.
I asked you to post back the SQL Statement that is written to the page, please post that information back to help troubleshoot the problem. I cannot troubleshoot with that information.
Kumel
WHAT DOES THIS MEAN? Can you give me an example?
Really?
I asked you to add this code to the page after the <body> tag:
the purpose of this code is to write the IP address and the Insert SQL Statement to the page after you press the submit button.
I need to to copy that information from the page into your reply post. I need to know what the Insert SQL Statement is.
