Data assist rotate/random display of content
Thread begun 12/06/2011 3:58 pm by jamie424562 | Last modified 12/07/2011 8:49 am by Jason Byrnes | 1139 views | 1 replies |
jamie424562
been trying to find a solution to randomise the content of data assist for images/banners.
so far I am using a simple rand but the pages load so darn slow its impossible, other solutions that i have found would mean changing alot of the coding and im not that experienced in php to do so, hence the extensions.
so far i have this:
$query_WADAsitebanners = "SELECT banID, banDate, banSupplier, banProfile, banLink, banLoc FROM sitebanners WHERE banLoc='CenterPage' ORDER BY RAND() ";
have also tried this with a limit 0,1 and limit 1, the above actually randomises better.
Please help.
thanks in advance
SELECT banID, banDate, banSupplier, banProfile, banLink, banLoc FROM sitebanners WHERE banLoc='CenterPage' ORDER BY RAND() LIMIT 1
would be the only way to do this using the recordset, this can be slow on a large dataset though.
if you are using MySQL 5, you may be able to speed this up by using a view. a view is basically a recordset that is executed on the MySQL Server.
we cannot offer support for creating the view, this is entirely dependent on your server MySQL Configuration.
if the server does support creating views, you can use phpMyAdmin or another GUI tool to access the MySQL Database, and run the following query:
CREATE VIEW randomBanLoc AS SELECT banID, banDate, banSupplier, banProfile, banLink, banLoc FROM sitebanners WHERE banLoc='CenterPage' ORDER BY RAND()
this will create a view named randomBanLoc in your database.
in your page, use the following SQL for the recordset:
SLECT * FROM randomBanLoc LIMIT 1
see the following for more on creating views:
create-view.html
