Error in WA_Store_Cart_Definition
Thread begun 12/06/2011 1:07 pm by glozinski107205 | Last modified 8/29/2012 2:04 pm by glozinski107205 | 4689 views | 10 replies |
glozinski107205
[06-Dec-2011 14:18:22] PHP Warning: Missing argument 19 for WA_Store_Cart_Definition::AddToCart(), called in /home/silk2pl/public_html/webassist/plugins/shopping_cart/add_to_cart.php on line 203 and defined in /home/silk2pl/public_html/WA_eCart/WA_Store_Cart_PHP.php on line 34
[06-Dec-2011 14:18:23] PHP Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/silk2pl/public_html/webassist/plugins/shopping_cart/cart_editable.php on line 135
[06-Dec-2011 14:18:26] PHP Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/silk2pl/public_html/webassist/plugins/shopping_cart/cart_editable.php on line 135
how does one correc this thank you in advance
this error indicates that you added or removed columns from the cart object, but have not updated the add to cart behavior.
glozinski107205
how does one go about doing this thank you in advance.
you need to edit the add to cart button behaviors too have the code regenerated based on the new collection of columns
glozinski107205
without making a mess when it is blank should i have it now looking like
<?php echo $WA_Store_Cart->DisplayInfo("Name"); ?> and other rows that are blank
<?php echo $WA_Store_Cart->DisplayInfo("Price"); ?>
<?php echo $WA_Store_Cart->DisplayInfo("Height"); ?>
DiscountApplied =0
etc....
which ones need to be filled in?
Thank you
ps ...i was not the one that altered the ecart columns....this is why i do not which ones to change....thank you in advance
glozinski107205
Error in Cart Editable
[20-Aug-2012 16:17:31] PHP Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home6/silkpla1/public_html/webassist/plugins/shopping_cart/cart_editable.php on line 135
This is happening again. Thank you in advance.
send a copy of the webassist/plugins/shopping_cart/cart_editable.php so i can investigate the code.
glozinski107205
change line 135:
mysql_free_result($Taxes);
if(is_resource($Taxes)) mysql_free_result($Taxes);
