W3C Validation
Thread begun 12/06/2011 6:35 am by fxs430566 | Last modified 12/07/2011 8:28 am by Jason Byrnes | 2832 views | 3 replies |
fxs430566
W3C Validation
I can't validate pages that use the social media share buttons because they do not pass W3C validation. is it possible to fix?
HTML Validation
Errors: 21 Instances: 26
Required attribute "alt" not specified - ID: 127 - Instances: 6
Files: 1
index.php - Instances: 6
Line: 95 Column: 396 - …title="Facebook"> <img src="webassist/social/icons/facebook.png" /> </a> </div>
Line: 120 Column: 386 - …eight=415');"> <img src="webassist/social/icons/google_buzz.png" /> </a> </div>
Line: 132 Column: 275 - … ."><img src="webassist/social/icons/mail.png" title="Mail" /></a> </div>
Line: 133 Column: 123 - …st/social/icons/print.png" onclick="window.print()" title="Print" /></a> </div>
Line: 134 Column: 277 - …<img src="webassist/social/icons/favorites.png" title="Bookmarks" /></a> </div>
Line: 150 Column: 135 - … 20s.JPG" width="500" height="350" border="3"style="color:#b8ab98;"/> </p></td>
There is no attribute "size" - ID: 108 - Instances: 1
Files: 1
index.php - Instances: 1
Line: 101 Column: 25 - <g:plusone size="medium" count="false" href=" …
There is no attribute "count" - ID: 108 - Instances: 1
Files: 1
Line: 101 Column: 40 - … <g:plusone size="medium" count="false" href=" …
There is no attribute "href" - ID: 108 - Instances: 1
Files: 1
Line: 101 Column: 53 - …sone size="medium" count="false" href=" …
Element "g:plusone" undefined - ID: 76 - Instances: 1
Files: 1
Line: 101 Column: 176 - … "></g:plusone>
There is no attribute "data-url" - ID: 108 - Instances: 1
Files: 1
Line: 114 Column: 42 - … <script type="in/share" data-url=" …
General entity "r" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 117 Column: 69 - …w.stumbleupon.com/hostedbadge.php?s=4&r= …
Reference to entity "r" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 117 Column: 70 - ….stumbleupon.com/hostedbadge.php?s=4&r= …
Required attribute "type" not specified - ID: 127 - Instances: 1
Files: 1
Line: 117 Column: 202 - … "></script>
General entity "noui" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 119 Column: 123 - …en('http://www.delicious.com/save?v=5&noui&jump=close&url='+(' …
Reference to entity "noui" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 119 Column: 127 - …save?v=5&noui&jump=close&url='+(' …
General entity "jump" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 119 Column: 128 - …ttp://www.delicious.com/save?v=5&noui&jump=close&url='+(' …
Reference to entity "jump" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 119 Column: 132 - …//www.delicious.com/save?v=5&noui&jump=close&url='+(' …
General entity "url" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 119 Column: 139 - …elicious.com/save?v=5&noui&jump=close&url='+(' …
Reference to entity "url" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 119 Column: 142 - …cious.com/save?v=5&noui&jump=close&url='+(' …
General entity "title" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 119 Column: 282 - … ')+'&title='+encodeURIComponent(document.titl…
Reference to entity "title" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 119 Column: 287 - … ')+'&title='+encodeURIComponent(document.title), '…
There is no attribute "alt" - ID: 108 - Instances: 1
Files: 1
Line: 131 Column: 213 - … " alt="Digg" title="Digg"></a> </div>
General entity "body" not defined and no default entity - ID: 25 - Instances: 1
Files: 1
Line: 132 Column: 60 - …ns"> <a href="mailto:?subject=Subject&body=Checkout this link: …
Reference to entity "body" for which no system identifier could be generated - ID: 325 - Instances: 1
Files: 1
Line: 132 Column: 64 - … <a href="mailto:?subject=Subject&body=Checkout this link: …
There is no attribute "bordercolor" - ID: 108 - Instances: 1
Files: 1
Line: 147 Column: 82 - … width="100%" border="3" cellspacing="0" cellpadding="5" bordercolor="#b8ab98">
this is an issue with the face book api code, the face book api does not use validatable code.
fxs430566
Ok, but what happens when a new browser version drops support which will in turn break the page?
then facebook will need to update their api with code that will not break the page in that browser.
