Captcha
Thread begun 12/05/2011 3:17 pm by brian432984 | Last modified 5/24/2013 8:58 am by Jason Byrnes | 4429 views | 10 replies |
brian432984
Captcha
I've looked in the forum under Capcha problems but couldn't really see anything that helped.
I have just created a form (my first using Form Builder) and the Captcha image doesn't show:
free-trial.php
I have checked and the webassist folder, sub-folders and captcha security files are on my server and the code is in my file. Not sure what to do.
Couple of other questions while I'm here:
1. can't see anything about a re-direct page - can I do this? Is there a tutorial?
2. I need to add a file attachment files to this when it is working. If I add multiple file upload fields, will they conflict of it is OK?
Brian
if you try to browse to the captcha image directly:
MOM_T___.TTF
it show the following error:
Fatal error: Call to undefined function imagecreatetruecolor() in /var/www/vhosts/wgonlinebrochures.com/httpdocs/webassist/captcha/wavt_captchasecurityimages.php on line 89
the captcha image relies on the GD Library and the True Type library being enabled for the php server, the error message means that one or both of these libraries are not enabled. You will need to contact the host to have these libraries enabled fro the php server.
In the server behaviors panel, (Window -> Serve Behaviors) Double click the universal Email server behavior and set the go to page to set a redirect.
multiple file uploads on the same page is fine.
Jonas
Sam problem capcha image dont show
Heres the address: kontakt.php
the file that should generate the captcha image:
is not uploaded to the server.
make sure to upload the entire webassist folder.
Jonas
Thanks!
Thanks for the reply! Was not sure which file I needed.
Massimo
the same problem for me
captcha page link are:
wavt_captchasecurityimages.php?
and get some errors
the errors mean the webassist/captcha/fonts/MOM_T___.TTF file has not been uploaded to the server.
Massimo
yes the fonts was missed (I don't know why! They aren't in my local site folder. I find it into local server folder only), but not work
teresa328019
capcha image broken
I am having the same problem on my form. The files have all been uploaded to the server but I get a broken image for the capcha.
I just updated the location of the form....capcha is at the bottom of the page.
http://sisocare.com/applicationform2.php
