Cannot connect to MySQL on HostGator
Thread begun 12/05/2011 9:05 am by clinton178625 | Last modified 12/06/2011 11:32 am by gruant2000381341 | 9543 views | 2 replies |
clinton178625
Hi Guys
Has anyone had trouble connecting to a database on Host gator server? and if so what are the settingsd needed? becasue i cannot get my dreamweaver to connect and i have tried everything? i spoke with host gator and they tell me i should be able to connect they have opened ports for me allowed my ip etc etc.
Cheers Clinton
you started another thread for this issue, in that thread I started a support ticket so we can investigate the problem with you.
gruant2000381341
this is how you do it remotely with hostmonster.....probably similar with host gator
not sure though, never used them
Log into your hostmonster account and click on "MySQL Databases" then under "Users" create a new user and password if you don't already have one you want to use.Then add that user to the database you wish to work with through Dreamweaver.
Now open Dreamweaver, create a new blank PHP page, then at the top bar click on "Site" then "New". Leave the "Local Info" as it is, but click on "Remote Info" instead and change the access type to FTP.
Here are the settings you'll need to fill out:
FTP host = your domain name or IP (the IP can be found in the Control Panel)
Host Directory = public_html (or public_html/addondomain)
login = control panel (cpanel) username
password = control panel (cpanel) password
Next click on 'Testing Server' then change the 'Server Model' to 'PHP/MySQL' and access to FTP. Use the same account information as above, and if Dreamweaver asks for a 'Remote Info Page', simply use www.yourdomain.com
Now to connect to your account and set up a connection to a database.
Up at the top menu bar in Dreamweaver click on 'Window' then 'Databases'. This will bring up a menu on the side bar, if it is not already up, where you can click on the + button and set up a 'MySQL Connection'. Label it what you would like in the 'Connection Name' and use these settings:
MySQL Server = localhost
Username = The control panel username then '_' and MySQL database username
Example: cpanel_mysqlname
Password = Password to the MySQL database username
Database = Click 'Select' and choose your database
Then you can test the connection to see if your settings are correct.
