Prior Version error after updating to DFP 2.04
Thread begun 12/04/2011 5:19 pm by eric284736 | Last modified 5/14/2012 1:32 pm by sandy170299 | 4095 views | 7 replies |
eric284736
I just upgraded to DFP 2.04 not realizing I already had the image functions in UE 4.
But when I added an upload to a DataAssist form I get the red exclaimation symbol and (prior version) in the Servers Behavior panel.
How do I remedy that?
thx
Eric
Uninstall Universal Email and Digital File Pro from the extension manager, then re install Universal Email 4.
also delete the Dreamweaver Cache file from the users configuration folder:
after reinstalling UE4, you will need to edit the upload file behaviors that you added to update the code.
eric284736
Thanks Jason!
sandy170299
Jason, I'm having the same problem, except that I'm also getting additional code errors. I DID delete and reinstall everything, according to the instructions, but I am still getting errors.
This is my code on the insert page:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../p7lsm_img_1/fullsize/",
'FileName' => "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "600",
'ResizeHeight' => "",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../p7lsm_img_1/thumbs/",
'FileName' => "".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."",
'ResizeType' => "3",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "picFile", "0", "", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "thumb", "0", "", "true", $WA_UploadResult2_Params);
These are the errors I'm receiving:
Notice: Undefined index: WA_UploadResult1 in C:\xampp\htdocs\wmapartments\admin\slideshowpics_Insert.php on line 63
Notice: Undefined index: WA_UploadResult2 in C:\xampp\htdocs\wmapartments\admin\slideshowpics_Insert.php on line 77
It's only local right now, so you can't browse it on a server anywhere. Thank you.
It looks like you have set the File Name to use the Server File Name variable, that wont work.
The Server File name variable is created after the image has been uploaded to the server. it is based on the File Name setting and the If File Exists on server settings.
Using the server file name variable for the file name setting is a chicken before the egg type of situation.
use the default "[FileName]" in the File Name setting of the upload behavior.
sandy170299
Thanks, Jason. The only time I should use the 'server file name' reference is during updates and inserts. Is this correct?
yes, that is correct.
sandy170299
Thank you!
