How to write query to retrieve csv values
Thread begun 12/01/2011 11:01 am by Jedi | Last modified 12/06/2011 8:37 am by Jedi | 5922 views | 10 replies |
Jedi
Hi, I have a website where I want to display all records by city. The city column in the table has cities stored in csv values. How do I qery the database to display the information by one city then by all cities?
Thanks in advance
Ian S
So your database column for cities might read...
Manchester, Birmingham, London, Swansea, Leeds ?
Assuming the recordset is called rscity and the field name for city is called 'city' you could try to put them into an array such as
$citynames = explode(",",$row_rscity['city]);
Then the cites would be stored in the array so
$citynames[0] = Manchester
$citynames[1] = Birmingham
$citynames[2] = London
etc, etc
Cheers
Ian
Jedi
Thanks Ian, That certainly does work. This is my dilema however: I will have a product that is offered for certain cities which could be up to 40 cities, and then other products that are offered to other cities. When the product is put into the database the input will use a mulitple select menu to add all the cities that the product will be offered to. This creates a column that has csv data.
Now when a customer is back on the website I want to show that product to only the cities that it is offered in. I am looking for a way to not be so labor oriented.
Thanks again for your help.
Ian S
OK, so you never actually know how many cities might be related to a product?
If its not too late in the project I would look at creating a separate table for this data so you can have many cities to one product, rather than storing it as CSV data.
e.g. your Cities table would have a structure such as
cityid unique ID for the record
productidfk id that links to the product ID
cityname name of the city
then you can write a query to pull back the product and related city detail and filter it out as required.
Cheers
Ian
Jedi
Hi Ian,
I did think about that route. The issue is however that I will have hundreds and possibly thousands of products that will change on a weekly basis. Some will be in all major cities and some only in some cities. So, I was looking for a solution whereby when a product was added that multiple cities could be added as well. And not have to then go to the city table and make hundreds of entries for the product. I hope I explained this correctly.
So, I am looking for a way to not only add the cities to the product but also be able search by state for the cities that contain the product as well.
you need to use a linking table as suggested by Ian.
and use the Data Assist Manage relational table behavior on the products insert and update pages to assign cities to the product.
Andrew reded wrote a good tutorial for using the manage relational table behaviors here:
showpost.php?p=84393&postcount=17
to be able search by city and state you will need to use a join query to return data from the products and cities table using the linking table to create the relationships.
see the following for details on joined queries:
sql_join.asp
Jedi
Thanks Jason,
You are right and it worked perfectly. One last question pertaining to the multiple relational behavior: Is it possible to use it for more than one option? I put cities, states, zip codes, and ip addresses in the options table, and I'm wondering if I can apply the same process to each option? it looks like I will be able to but I wanted to ask before I blow it up.
Thanks,
no, at this time it can only be used for one option
Jedi
Ok, thanks. Can you apply more than 1 manage relational table behaviors to an update form? By that I mean I have one now for cities. Can I do another for sates?
well, the state a city applies to should not be done on the products page, it should be donme when inserting or updating the city to the database.
