Google Analytics Bugs Out DataAssist
Thread begun 11/30/2011 12:25 pm by bill173836 | Last modified 11/30/2011 1:04 pm by bill173836 | 2605 views | 4 replies |
bill173836
Im using DataAssist to create a field to hold the Google Analytics code the problem is when I insert or update the form. The code goes crazy and inserts only part of the code. For instance the following code when inserted.....
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-AccountNumber']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
</script>
Only places this part in the database
var _gaq = _gaq
Then ignores all the rest or puts part of it in a different field.
I'm using PHP 5.2 mysql with the field set as a text field.
I own Powerstore 4 and see that it's possible to store the data in a database so any idea what gives?
try adding the following at line 1 of the insert and update pages:
if(!empty($_POST)) {
    foreach(
$_POST as $key => $value) {
$_POST[$key] = str_replace("|""&#124;"$value);
bill173836
Didn't make any difference at all.
the bulletin board software converted the pipe html entity to a pipe,
on this line:
$_POST[$key] = str_replace("|", "|", $value);
the second | should be:
& # 1 2 4 ;
i added spaces between each character to prevent it from being converted to the pipe again, you will need to remove the spaces between characters.
bill173836
That worked. Thanks.
