Transfer from Localhost to Online
Thread begun 11/29/2011 4:00 am by paul283230 | Last modified 11/30/2011 8:55 pm by paul283230 | 4021 views | 3 replies |
paul283230
Can sombody please tell me what you have to change when transfering from a Localhost to Online besides connections to the mysql databases
I have installed PowerCms on a localhost everything is working fine at last
up to now I have not added any of the functions to my pages yet but when I uploaded the website to a directory online for testing before it goes live i am getting no pages but errors
Example:
Warning: main(../images/installed.png) [function.main]: failed to open stream: No such file or directory in /data01/myhostingname/public_html/new_website/WA_Globals/WA_Globals.php on line 60
Fatal error: main() [function.require]: Failed opening required '../images/installed.png' (include_path='/usr/lib/php:.:/usr/php4/lib/php:/usr/local/php4/lib/php') in /data01/myhostingname/public_html/new_website/WA_Globals/WA_Globals.php on line 60
copied the installed.png into ../images/ from a previous user on the forums who was having the same error with no joy.
Must admit I am really regretting buying PowerCMS the time it has took to get my website to work has been a nightmare Webassist have some very good functions over the years I have bought them all ( except PowerStore and ImageGallery because you can only use them per site) to help me and save me time but this one!!
Is there any way you can remove PowerCMS and any reference to it.
Regards Paul
paul283230
Finally got the PowerCMS install menu to appear but could somebody tell me how to remove PowerCMS from my website myHosting are using pHP version 4.4.5 and PowerCMS needs version 5 or above and they are not going to change it for a few weeks yet.
Regards Paul
in the connections folder, delete the PowerCMSConnection.php and the installed_cms.txt file.
delete the WA_CMS, install_cms and admin_cms folders.
on any pages you have added CMS Content areas, remove the code for the content area and the require once lines to attach the CMS supporting files.
paul283230
Jason,
Thank you for getting back to me worked a treat completly removed PowerCMS for time being I will be using it again.
When I do I will probably be getting in touch did some checking after I uninstalled everything from my website the PowerCMS setup was saying only version 4.4.5 for PHP was installed went to my cpanel on my hosting it was showing version 5.2.17 installed?
Regards Paul
