checkout error
Thread begun 11/27/2011 12:35 am by chiakioda428401 | Last modified 12/01/2011 11:18 am by chiakioda428401 | 1399 views | 2 replies |
chiakioda428401
checkout error
when I test the checkout process, I get the following error
Notice: Undefined property: eCart1_Definition::$WeightUnits in E:\xampp\htdocs\chabuta\confirm.php on line 500
Fatal error: Call to undefined function curl_init() in E:\xampp\htdocs\chabuta\WA_eCart\WA_eCart_USPS_PHP.php on line 127
I just followed the checkout wizard using usps account.
I have no idea what I did wrong and where to look at.
for the first error, what is the code at line 500 of the confirm.php page?
for the second error, you need to enable curl in the php.ini file.
See this page for details on enabling cURL in xampp:
how-to-enable-curl-php-extension-in.html
chiakioda428401
thanks
Hi Jason
Thank you very much for the info, I could fix them.
For the first error, the weight object was not set as number, it was set as text.
