Shopping cart display problems
Thread begun 11/25/2011 11:56 am by elewis93815 | Last modified 11/29/2011 7:30 pm by elewis93815 | 2183 views | 4 replies |
elewis93815
He have created a store with 11 products. All are in place, all have add to cart buttons. The problem is, when we purchase items all do not go into the cart (order_display.php). In testing we discovered that the first two items we add will go through fine, however, when we attempt to add a third or more, the item will add (only in quantity) to the 2nd item purchased but will not create a third line item.
I have attached all relative files. Any assistance is greatly appreciated.
Jackie
please send a link where i can see the problem.
elewis93815
This is the link: shop.php
the ID for each item is the same.
the cart usses the ID as a unique identifier.
on the shop page, next to the quantity text box for each add to cart button is the hidden form element that passes the id.
select each one of those hidden form elements and set the initial value to the ID for that products.
you can use the recordset column since you do not have a repeat region. you are creating static add to cart buttons, so will need to set the ID statically.
elewis93815
Thank You Jason! We followed your instructions and it works great!
Thanks again!
