PowerCMS Builder Image Issue
Thread begun 11/24/2011 10:41 am by laura_ellis427550 | Last modified 12/22/2011 12:02 pm by ray293736 | 3140 views | 7 replies |
laura_ellis427550
I have a site with PowerCMS Builder installed. The site has several pages that are identical in layout and CSS styling. When I insert an image into a content area on one page everything appears exactly as it should. If I then change the image to a different one, that is exactly the same size, it causes the image and the content next to it to drop down slightly.
What is causing this?
Thanks,
Laura
can you send a link to a page that demonstrates this issue so i can investigate the cause.
laura_ellis427550
upholstery.php - this page shows the image as it should appear.
about.php - this page is exactly the same but the image drops slightly when managed through PowerCMS. Images on the other pages also do so I've had to take them of the CMS for the time being.
sublucentBeta Tester
Paragraph tags around images
I'm having trouble with the editor inserting paragraph tags around images. Looks like the same problem Laura is having. Is there a fix for this?
Anyone have any ideas? Deadlines approaching...
No replies...
No one else had a problem with this?
ray293736
Depending on how your site is structured in Dreamweaver, it may be possible to add a style for the P tag.
For example <div id="imagecontainer">YOUR POWERCMS IMAGE CONTENT HERE</div>
then have
#imagecontainer p{
margin:0;
If your images are accompanied by text, it might be more problematic.
