eCart row number
Thread begun 11/24/2011 2:35 am by juha.morsky57580 | Last modified 11/28/2011 9:49 am by Jason Byrnes | 1208 views | 1 replies |
juha.morsky57580
eCart row number
How can I retrive eCart's row number, like this:
1. ProductX 115.00€
2. ProductY 100.00€
3. ProductZ 140.00€
Generally iI need to "row number" to the Cart while I'm adding new product to Cart, because I need to add "row number" to several other tables when I checkout.
The best option is to generate running number to ID field in the Cart.
Regards
Juha
I'm not sure i follow what you are trying to accomplish.
In the add to cart button, you should be assigning a unique value for the cart ID column, you should be using this column to refer to the product, not a line number count.
