Headers already sent problem...
Thread began 11/24/2011 2:26 am by martin400112 | Last modified 11/24/2011 7:09 am by CraigR | 565 views | 1 replies |
martin400112
On piccolaonline.co.uk, after following the menu through you a subcategory page such as:
subcategory.php?id_Subcat=21
the page displays correctly when it is first looked at, but as soon as an item is added to the cart, the item is added to the cart and this warning appears:
Warning: Cannot modify header information - headers already sent by (output started at /home/piccolao/public_html/subcategory.php:13) in /home/piccolao/public_html/subcategory.php on line 191
I have looked at line 191 and cannot see anything wrong with it, but the line appears to refer to the eCart Object. I also cannot find anything wrong in the eCart Object.
I have attached both the subcategory page and the eCart object page.
Any info would be gratefully received!
Many thanks,
Martin
headererror.zip
CraigRBeta Tester
you have spaces between the php tags on line 13 on subcategory.php
