Can't Edit Existing menus since upgrade to 2.0.6
Thread begun 11/23/2011 9:58 pm by Lee Firth | Last modified 12/06/2011 11:14 pm by Lee Firth | 3033 views | 4 replies |
Lee Firth
I have two issues after updating to 2.0.6.
1. The release notes state: "Updated the Property Inspector so that Menus only have one button – 'Edit Menu', instead of 'Edit Contents' and 'Edit Design'."
Take a look at the attached menu_writer_properties.jpg file. This isn't the case with me.
2. I can't edit any existing menu writer menu's, when the GUI starts to load I get the error message in error_msg.jpg
anonymous
Did you try deleting the Dreamweaver Cache file?
It is outlined in here: common_installation_issues.pdf
That typically is the cause of the problem you show there.
Best regards,
Brian
Lee Firth
I've been around WebAssist long enough to know that's the first thing you do. I un-installed the extension deleted the WinCache file and the SiteCache folder. Then reinstalled the extension.
Doesn't make any difference.
Lee Firth
This issue has been resolved thanks to Ray Borduin. If anyone is having similar issues this was caused by using an ampersand in the menu's theme name and had nothing to do with upgrading to 2.0.6. I had called my theme "Bright & Light" when this was changed to "Bright and Light" it worked fine.
