Server Error, SQL Synax Error - on initial install
Thread begun 11/22/2011 4:50 pm by erinlima318673 | Last modified 11/23/2011 2:25 pm by Dani Chankhour | 2393 views | 4 replies |
erinlima318673
I really hope someone can help me with this. I have spent the better part of the day reading through the forums on this site and countless others trying to figure out why my fresh install of DataAssist is not generating functional pages.
We currently use Yahoo as our host, so chmod changes are difficult but doable. Our db/table was built using phpMyAdmin.
Upon building the standard pages with the DataAssist Wizard, we verified the server bindings in Dreamweaver CS4, and uploaded the files to the webserver.
We are able to access the Search page, but when we click submit, we get the following error:
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Condition, Description, StockNumber, Price, Status FROM usedbikes ORDER BY Model' at line 1"
When we try to access ANY of the other WA DataAssist generated pages, we get a "500 - Internal Server Error".
We have tried modifying the permissions of each of the files using FileZilla and have confirmed they have been updated to 755, per another posting in which the user was having a similar issue.
Still not working.
Scripts.log file showing the following errors when trying to access this page (gpmotorcycles.com/usedbikes_Insert.php):
[22-Nov-2011 16:08:42] PHP Warning: require_once(WA_DataAssist/WA_AppBuilder_PHP.php) [<a href='plugins/function.require-once'>function.require-once</a>]: failed to open stream: Permission denied in /usedbikes_Insert.php on line 2
[22-Nov-2011 16:08:42] PHP Fatal error: require_once() [<a href='plugins/function.require'>function.require</a>]: Failed opening required 'WA_DataAssist/WA_AppBuilder_PHP.php' (include_path='.:/include:/usr/lib/php') in /usedbikes_Insert.php on line 2
Scripts.log file showing the following errors when trying to access this page (gpmotorcycles.com/usedbikes_Update.php):
[22-Nov-2011 16:06:28] PHP Warning: require_once(WA_DataAssist/WA_AppBuilder_PHP.php) [<a href='plugins/function.require-once'>function.require-once</a>]: failed to open stream: Permission denied in /usedbikes_Update.php on line 2
[22-Nov-2011 16:06:28] PHP Fatal error: require_once() [<a href='plugins/function.require'>function.require</a>]: Failed opening required 'WA_DataAssist/WA_AppBuilder_PHP.php' (include_path='.:/include:/usr/lib/php') in /usedbikes_Update.php on line 2
Please help!
erinlima318673
re: Server Error, SQL Synax Error - on initial install
The syntax error has been resolved - not sure how, but I reverted my MySQL database back to 4.1.14 and PHP back to version 5.2.12, and the Search page now works - and properly redirects to the results page.
The Insert, Update and Delete pages all still return 500 - Internal Server Errors.
Please help! If I can't get this resolved quickly, I need to speak to someone about a refund. I have lost 2 whole days on this issue and need to find a solution that works.
Dani Chankhour
The 500 error indicate there is an error on the page. On top of the page place the following code:
ini_set('display_errors', 1);
error_reporting(E_ALL);
Reload the page and post back with the error message.
erinlima318673
added that code to the top of the code on each of the pages and they still only show
No other error messages are shown.
I have tried viewing the page in Firefox, Chrome, and IE8 - all with the same result.
The script error message from my original post seems to provide the only clue as to why these pages are not working. Each of the pages that are trying to call the WA_DataAssist/WA_AppBuilder_PHP.php file using the require_once php function are meeting with fatal errors and returning the Internal Server Error message.
The pages that do NOT require the WA_DataAssist/WA_AppBuilder_PHP.php file seem to load with no errors.
Dani Chankhour
I have opened a support ticket to further look into the issue:
