Upgrade problem to 2.0.6.
Thread begun 11/21/2011 3:09 pm by rmruda390861 | Last modified 11/22/2011 5:23 pm by rmruda390861 | 1688 views | 3 replies |
rmruda390861
Cannot upgrade to 2.0.6. with CS4
Deleted WinFileCache.dat - made no difference.
Then also deleted previous version I had (2.0.3)
Error I am getting is:
"Can't create folder
'C:\Users/Administration/AppData\Roaming\Adobe\Dreamweaver
CS4\en_US\configuration\Shared\WebAssist\CSSMenuwriter\presets\Accent'. "
Please advise - thanks
Dani Chankhour
Try deleting the configuration folder and installing the extension again.
First rename the C:\Users/Administration/AppData\Roaming\Adobe\Dreamweaver
CS4\en_US\configuration to
CS4\en_US\configuration_old
open the extension manager and remove all extension and install MW again.
rmruda390861
Thank you for your reply Dani.
I presume you mean delete Dreamweaver extensions only right? Anyway I will try it but not happy about this. I have 20+ extensions.
rmruda390861
OK it worked - I just deleted the Dreamweaver extensions.
Thanks,
R
