Edit Captcha Code
Thread begun 11/21/2011 4:08 am by dsnoyes418343 | Last modified 11/21/2011 6:23 pm by dsnoyes418343 | 1460 views | 2 replies |
dsnoyes418343
Edit Captcha Code
I forgot to select the 'refresh code' option when I set up the form on the page below - how can I add that after the fact? Is there a way to go back into the wizard? Or do I have to edit the code now?
contact.php
Thanks!
What tool did you use to apply captcha? Form Toolkit?
If you used form Toolkit, In design view, select the captcha image, this should show an edit option in the property inspector, click the edit button to edit the captcha settings.
dsnoyes418343
Slick! Thanks!
