Error in UE4
Thread begun 11/19/2011 12:40 am by Kumel | Last modified 11/21/2011 11:03 am by Kumel | 4776 views | 8 replies |
Kumel
Problem in UE4
I created new DATASSIST PAGES & also inserted Universal Email into it to upload images & etc. Images are stored through file names in DB & then using Img placeholder the image is shown on result pages & etc.. So I created a new DB called , uploads. It has UserID , UploadID, File name, Status & etc.. So after inserting the dataassist wizard pages, on result page it displays the entire DB entries.. But i want to see only Logged in User's DB.. May be like filtering Logged in UserID & from upload DB, filtering UserID then it must show only his/her's uploads..
So please help me on this..
Kumel
This post has been deleted.
iansheldon422428
When you user logs in are you storing the unique ID for the user in a session variable?
What you need to do is either update your Recordset Select statement to only select records where the UserID = the session that contains the user ID, or apply the Data Assist Search Server behaviour and select to filter the User ID field by the Session Variable.
Cheers
Kumel
OK now that was easily understood.
I have a page where there is a img tag, & img value is stored in DB & using img tag it displays the img linking from DB, code used is->
<img src="snaps/thumbs/<?php echo($row_WADAuploads['Img']); ?>.jpg" alt="" name="Img" />
So when i apply show region it still shows the small img tag thing.. so how do we hide that when DB is empty in IMG FIELD. (database) please tell me how do we use show region?
put an if statement around the image tag:
<?php if($row_WADAuploads['Img'] ! = "") { ?>
<?php ?>
the if statement checks to make sure the Img column in the database is not blank.
Kumel
After adding that even if the value is there in DB, its not shown...
send a copy of your page please
Kumel
there u go.
you have changed the code around.
i am assuming this is the line giving you thje probelm?
<?php if($row_WADAuploads['AniSnapImg'] = "") { ?>
<img  src="snaps/thumbs/<?php echo($row_WADAuploads['AniSnapImg']); ?>.jpg" alt="" name="Img" />
<?php ?>
this is not correct syntax for the if statment. using this:
you are setting the value of the AniSnapImg column to be ""
it should be:
<?php if($row_WADAuploads['AniSnapImg'] != "") { ?>
to check if the value of the AniSnapImg column is not equal to ""
Kumel
Oh!! Oops!! sorry!! anyways thnks..
Please help me on this ---> showthread.php?t=23754
